Mine seems to do it about 500 km's before an oil change is due. I check the level, but all is fine. So I add about 1/2 Litre just to see if it makes a difference, and the light does go out. I then don't have a problem until the next oil change is due. I will ahve the dealer take a look and see if its a sensor problem. Maybe it is set too high, and if you loose just a touch, then it goes off. I dont know.
GMC 3500 4X4 cc SLT Dmax/Allison - The BEST truck out there!
Pictures of truck:
http://www.geocities.com/cowboy_2222ca/duramax1.html
New PICS Without SNOW!
http://www.geocities.com/cowboy7777ca/duramax.html
