Results 1 to 5 of 5
Thread: ALL WHEEL DRIVE CONVERSION NOW AVAILABLE FOR C4500/C5500
    Nov 2000
    Texas
    Thanks to SK.
    http://www.monroetruck.com/whatshappening.asp
    * Conversion available with diesel or gas engines, manual or automatic transmissions
    * Available in all GVWRs offered by GM
    * In-cab air switches with dash lights for front axle engage and high/low shifting
    * Carraro axle capable of being rated up to 8000#
    * Offset differential bowl to minimize frame height
    * Double-carden joints in axle provide 40 degree turn angle
    * Factory steering gear,progressive load damper and ABS maintained
    * 4WD available with all factory fuel tank options
    * Initial production is available in 5.13:1 axle ratio
    * Heavy-duty 2-speed Isuzu transfer case
    * 2.09 low gear ratio; 1:1 high gear ratio
    * Equipped with oil pump and oil cooler
    * Front axle de-clutch
    TxDoc's Photos
    Member #5547
    May 2002
    Southern California
    Will this be the 'factory' 4X4? I had heard that 4X4 C-4500 and 5500 models were to be made in-house.
    Nov 2000
    stoneham,ma 02180
    Now you would think that GM would want to do the 4x4 since that was part of the reason to build this new model.To compet with ford 450-550 4x4 models
    Nov 2000
    stoneham,ma 02180
    Was GM going to start production of the 4x4 on the 4500-5500 series truck for the 2004 production?And does any one have any good pics showing the 4x4 on the truck ,Monroes does not show the whole truck sitting flat.
    Dec 2001
    Culleoka,TN. USA
    It looks like the Izusu transfer case will be used. They've been making em for a while for other applications. They are GM's Japanese counterpart for trucks.
    I wonder if they will be shift-on-the-fly.
    zip
    Zip. Go Vols!
    Diesel Page member #8842
    http://community.webshots.com/user/dnstclr
    2002 K2500HD DMax White EC LWB
