Vadmax2003
Forget about that 5th wheel Doc. Your TT weighs a ton less than an equivalent 5th wheel without all the windage. Instead go to www.aemfg.com and check out their Weight distributing hitch. Also www.jordanbrake.com can fix you up with a brake controller that's second to none. After that you'll think you're towing a 5th wheel and still have the bed of your truck available. I was a semi-trailer driver and I'll pull a TT anytime before a 5th wheel. In my signature check out my generator setup that's a winning setup as well.We boondock in the desert and it's like we're hooked to shore power. Stu
2002 GMC 2500HD D/A. CC. LB. INDIGO BLUE <br />Custom Lining bedliner,Quick & Easy hitch receiver,Snugtop cap,Trailback running boards,135 Gal. Auxtank,Moryde RL suspension,Alison deep sump, Jordan Ultima 2020 brake controller.<br />26\'Sunnybrook 26CKS TT,<br /> Blue Ox equalizing hitch,2 Honda EU2000i generators in parallel. <br />25\'Bayliner Flying Bridge cruiser.
