Gee,
Is it really a good idea to be drilling into any electronic device? If you own an O3, Take special warning before attempting to disable "key in" chimer when door is open.
01,02's
The door chimer tone is already annoying enough! A hole in drilled in the small chimer speaker would just badly distort the already annoying sound or destroy the speaker coil. This can't be good on the driver electronics module! If it's driving you nuts, disconnect the door sense wire as indicated on some of the other posts on this thread.
If you own an 03, forget tampering with the door wiring or the chime speaker! It's all tied to main CPU and appears to be using the door mounted stereo speakers. Tampering with a 03 door control wiring could lead to a total system failure? In 03, the door functions/wiring is all matrixed for less wiring going into and from the doors. It's all scanned and monitored by common control buss/wiring to an On-board computer and is totally different than the 01 & 02's!
[ 11-17-2002: Message edited by: FisHn2DMax ]</p>
2003 GMC 2500HD SLT Crew Cab 4x4 D/A with all the toys! Rear seat DVD system with Bose 6 changer CD Stereo system. factory Extendable tow mirrors. Line-X sprayed bed liner, Westin Nurf bars, 285 BFG AT\'s on 16\" AR chrome pythons, 5\'er hitch, prodigy controller.
