The speaker for the door chime is mounted on a circuit board inside a computer module. The module is located under the steering column. This module runs all the stupid annoying stuff like door chimes, idiot message center, security system, etc. Unplug the module and take out the screws to open it up. Remove the speaker and put it all back together. The computer module needs to be plugged in or the security system will cause the engine will not run.
