I saw these things in a RV mag, what are they doing? What would be the advantage to using them? Is it just to make it stable while driving? Has anyone used them in the past? They say they push the wheels out about 2".
The spacers push the rear wheels out so they track in the same path as the fronts. This had become an issue when GM went to the IFS front end. This widening helps stability some and is also a help in snow/mud etc. since the rear wheels don't have to plow a new path.
John
VOLUNTEER FIRECHIEF "Without COURAGE, all other virtues lose their meaning" Truck Info
indigodually@hotmail.com
Member # 7674
Pulling many trailers including an '03 34' Montana 5'er adapted to G/N
Saw It ... Wanted It ... Had A Fit ... Got It...Then Sent It Back!
Is this something that some people do, or is it a way to get money out of your pocket? Is there any problems with using them?
I believe that there is some benefit, but they also are quite heavy (add considerably to unsprung weight), and they do add some to the hub/axle loading by way of increased leverage arm.
[ 04-12-2003: Message edited by: pinehill ]</p>
2001 2500HD D/A CC/SB 4x4<br />A.R.E. Z-series topper, CA 75-series boards, Bedrug, Fumoto valve, Amsoil air filter, Jan \'02 PCM updates,Transfer Flow 50 gal. crossbed aux. fuel tank, Bilstein shocks, 25 ft. Tahoe Transport toybox (9.6K loaded), Hensley hitch, Tekonsha Prodigy brake controller.
