Did you have any luck Bill?
I have a 3/4" impact, so hopefully that will do the trick for me next week, although I have come across some things that it wouldn't do (tractor implement stuff).
Btw, I had my front rotors turned twice under warranty for the same vibration issue you mentioned. After the 2nd time, they have held up ok.
\'02 Pewter 3500 LT CC LB 4x4 D/A G80<br /><br />Predator v1.11, Warn M15000, BFG 235-85-16 ATs, Crimestopper Remote Start, 2.5\" Front Leveling Cams, Prodigy Brake Controller, Nasta Nerf Bars, UNI Foam Air Filter, Fumoto Valve
