Results 1 to 20 of 27
Thread: Transmission fluid
Threaded View
  1. #7
    mdrag Guest
    Cool
    gdblake,
    Mobil 1 synthetic ATF is on the Allison Approved oils list (available as a pdf document download):
    http://www.allisontransmission.com/p...cationType=All
    However, only Transynd is approved for extended drain intervals, so if you use Mobil 1 ATF, you will have to follow the normal maintanence schedule.
    The OEM pan on our trucks is the shallow pan, and a comparison of the deep and shallow pans:
    STOCK SHALLOW PAN CAPACITY 7.4 QTS (ALL YOU CAN DRAIN)
    LARGE PAN CAPACITY 7.4 QTS + 3.2 QTS = 10.6 QTS
    TOTAL CAPACITY (DRY SYSTEM) W/SHALLOW STOCK PAN 12.7 QTS
    TOTAL CAPACITY (DRY SYSTEM) W/DEEP PAN 15.9 QTS
    TORQUE PAN BOLTS = 20 ft lbs
    TORQUE DRAIN PLUG = 25 ft lbs
    NOTE*
    1. Old suction screen seal may stick in.
    2. Allison filter has removable magnet.
    Part #s for the deep pan and internal suction filter for the deep pan:
    DEEP PAN SUCTION FILTER
    new part # 29537966
    old part # 29536891
    DEEP PAN
    part# 29536522
    PAN GASKET
    part# 29536526
    I listed the pan gasket - it is reusable and should not need replaced when changing pans.
    ON EDIT: The forum software edited the link, the last part of the link should read:
    GN3465EN. j s p
    Leave out the spaces bwtween the 'dot' and the last 3 letters. Or go to
    and chose PUBLICATIONS from the menu below the Allison emblem, then search BY PUBLICATION NUMBER - using GN3465EN.
