Okay, got both the front and rear changed. The rear was black and I had quite a few metal flakes on the magnet/plug and about 1/2 of a quart low, which is what I expected (Thanks to you guys/gals.) The front came out looking pretty dark at first and then turned into grey poupon. Again about 1/2 a quart low, but no big pieces on the magnet, just lots of metal dust. (Probably some effenciency engineer said to short every truck 1/2 quart and look at all the money they save on the high dollar synthetic. ) I went ahead and hit all 11 zerks while I was under there, and again thanks, cause I had only found 8 before searching.
Okay, now the part I need help on. In the front diff fluid was a bunch of yellow flakes. It looked like paint chips. I thought maybe the gears were painted and the paint wore off or the casting release materials coming out. Has anyone seen this and should I be worried
I did jack up both sides to get fluid out of the axel tubes. Now, should I check level in a week or two, or can I go on my merry way until the next oil change?
Thanks for the knowledge I am sure to recieve.
02 2500HD LT Dmax/Alli CC 4x4 Lt Pewter, Tan in, Amsoil, transynd, Bilsteins, Amsoil Air Filt, JK 4\" Exht, RollnLock, Rhino Liner, Remote start, alarm, High Idle, SPA DG211, Pred, Mega, Fumoto, Remote oil bypass, XL Tranny cooler, XM, Cell kit
