Results 1 to 2 of 2
Thread: Transmission Heat
    Dec 2004
    Oklahoma city
    OK, so I was crawling around under my 05 3500 today. Noticed something that has me wondering. The transmission return line from the radiator/cooler runs next to the exhaust down pipe. They are only 3/4 of an inch apart! With the down pipe at temps in the range of 1000, how can that keep from adding a lot of heat back to the returning trany fluid? Looks as if this would be especially true when the truck in not moving. Should there be a heat deflector between the down pipe and the trans return line to help keep the returning fluid from picking up extra heat?
    Feb 2001
    Collegeville, Pa
    I'll have to check mine as well, I added a nice heat shield on my 95 suburban, to protect the rear heater and A/C lines above the 4" exhaust.
    Tom McCauley (DP Member #513)
    "Tankers-ToyII" Loaded 05 D/A K-3500 CC, SRW. Deep pan on Allison w/Transyn. Edge Juice w/attitude, 4" Kennedy exhaust, 98 Gal. Transfer-Flow cross bed fuel tank, Leer 100XQ bed cap. Reese 14,000lb class V hitch w/ dual cam HP sway control. Tow 34ft. 32FKD Holiday Rambler travel trailer. GCW 20,360lbs
