Run Around
All,
I'm getting the royal run-around from GM. They are claiming that they've NEVER seen this before and, due to the mileage, are unable to do anything for me.
This is BULL***T - they have a design problem that causes the fluid to drain out and the Transfer Case to self-destruct and they don't let people know!?!?! Then they DENY they have a problem???
I think this may be the end of the road for me and GM...
Incidentally, the stealer wants $2K for the repair!!! He says the inside is all worn due to contact with the case....
Bill
_____________________________________________
2002 Silverado 2500HD LS DMAX/ZF, CC LB 4x4 Charcoal Grey, Line-X Liner, Back Country Nerf Bars, Century High C, Dual Alts, High Idle Mod with Trilogix CS-423 Remote Starter, Garmin GPS 15H with Skymaster Antenna, Rear Obstacle Sensing System, Autometer EGT/Boost Guages on Pillar, 600W Power Inverter, Unity 6" spotlight, Fumoto Valve with Threaded Cap, Warn Winch on multi-mount with front + rear receiver, And for you HAMS - HF/6M/2M/220/440/GMRS/1200MHz + Scanner with all the antennas to show for it!
