With the arch of the new springs you have probably changed the caster angle. Caster helps the wheel center itself. You should have something like 0-1 degrees positive caster,but that's just a guess. You may be able to find degree shims to install between springs and frt axle. Other than shims there's not too much you can do about it.
Does it have a slight wander when going down the road? Or the steering not feel as tight as it did b4? like your chasing it.
92 GMC std cab C2500, Kennedy high flow injectors,port matched, Banks exhaust & gauges, intercooler, 97 cooling, Turbo Master.A means for a Toy
