on the build sheet it says Rear axle standard and i checked the code on the net only to find the same result. does anyone know what ratio this standard is?
btw it is a 1983 C20 2wd
Thank you
Thank you
ill go out on a limb and say that if you have a hd 3/4 ton c6p option on the build sheet or the character in the 4th position of the vin is g and not f , then i think 3.73 is the std axle.
hope this helps
02 d/a 4x4 crew sb 100k w/original injectors
84 m1028 34k
thanks for your reply ill check it out
