Results 1 to 5 of 5
Thread: Rear disc brake conversion
    Feb 2001
    Collegeville, Pa
    Has anyone done a rear drum brake to disc brake conversion on a full floating GM axle?
    As most know the rear drum brakes are the pits! Been through different lining, new upgraded proportioning valve, adjustmenst seem to make a small improvement for about a week. I did some searching on the net and found some kits, some with very little in componets, and some with new master cylinder, proporting valve, hubs/bearings tubing etc. but with a hefty price tag.
    Tom McCauley (DP Member #513)
    "Tankers-ToyII" Loaded 05 D/A K-3500 CC, SRW. Deep pan on Allison w/Transyn. Edge Juice w/attitude, 4" Kennedy exhaust, 98 Gal. Transfer-Flow cross bed fuel tank, Leer 100XQ bed cap. Reese 14,000lb class V hitch w/ dual cam HP sway control. Tow 34ft. 32FKD Holiday Rambler travel trailer. GCW 20,360lbs
    Oct 2002
    Minnesota
    THE KITS I HAVE SEEN ARE ABOUT $75 AND YOU PROVIDE THE ROTORS AND CALIPERS. ONE PLACE TOLD ME I SHOULD NOT NEED TO DO ANY THING WITH THE PROPORTIONING VALVE BUT I DONT KNOW IF I WOULD GO OFF OF THAT. HERES THE NAMES OF THE PLACES I HAVE FOUND.
    http://www.tsmmfg.com
    http://www.shakerbuilt.com
    http://www.bluetorchfab.com
    LET US KNOW HOW IT TUTRNS OUT IF YOU DO IT, I HAVENT DECIDED YET IF I WANT TO TRY IT YET.
    TONY
    a5150nut Guest
    Tanker
    Take a look at this site http://www.akfabshop.com/alaskaoffroad/axle_tech.htm
    Lotts of good info.....
    Dec 2002
    Cincinnati, OH
    pirate4x4.com
    92 GMC std cab C2500, Kennedy high flow injectors,port matched, Banks exhaust & gauges, intercooler, 97 cooling, Turbo Master.A means for a Toy
    I've been doing a bit of research on rear disk conversions as well. Here's a little more info.
    Some experienced fabricators recommend buying a complete "take-off" rear disk parts set from a 2001 or newer 2500HD, when converting the FF axle equipped vehicles, then make adapters to fit the GM 10.5" axle. You may also be able to adapt the rear wheel sensors from the new truck brake/hub assys to maintain your ABS.
    In my case, I only need a light-duty rear disk setup, so I can use a 1/2 ton rear disk set from a 1999 Silverado/Sierra or newer.
    Vendors I have on file that produce rear disk conversions include:
    www.ssbrakes.com
    AP Racing 888-266-0696
    MP
