Results 1 to 2 of 2
Thread: Quadd steer questions
    Jun 2002
    Birmingham, AL
    Brother-N-Law has a CC Q-Steer truck and wants to raise the front to level the truck. Is there a special trick to this or can I just wing the T-bars and do a normal allinment? Also, how much tire and rim can you put under one of these things, stock. Will a set of Hummer II rims fit with 31" tires?
    Burner---------->
    2003 GMC SLT CC 4x4 SB-Cooper Tires-Speed Liner-Activator II-Full length ICI SS step bars B&W Goose & more to come
    -- Member #7527
    E-Mail -->Twomuchplay(at)AOL(dot)com
    Oct 2002
    Minnesota
    I HAVE SEEN 285/75R16 ON A 1/2 TON BEFORE WITH MINIMUM RUBBING. THE HUMMER WHEELS ARE 17'S I BELIEVE I WOULD TRY A 265/75. AND YOUR SPEEDOMETER WILL BE OFF.
