Hi folks,
As the subject states, my '94 suburban *occasionally* shakes at hiway speed (50-60). It is beginning to happen more often now.
The symptoms seem to me to be nothing like a tire balance issue...certainly not like balance problems I have had in the past. What it is doing these days shows no issues until running at hiway speeds for a few minutes. I then begin to feel a slight vibration...I can even hear a rumble before I begin to feel it. The vibration and noise grows steadily worse with maintained speed. If I allow the truck to coast to a stop, the vibration subsides as the speed decreases; however, if I brake to a stop, the vibration continues and is even made worse by a vigorous shaking right down to a complete stop as if a rotor were seriously warped. If I then get the truck up to 40mph or so and brake to a stop, no shaking at all but a nice smooth stop. If I get it back up to hiway speeds, same thing all over again. It seems as if sometimes turning a corner may have some relation to whether or not it does this on the next stretch of hiway.
Could this be bearings? Ball joints? What else might produce this kind of behavior?
Thanks for any insights!
-- Matt Brown
Matthew Brown<br />1994 K2500 Suburban 6.5TD - DP timing gears/Phazer, \'97 cooling mods, FSD cooler<br /><i>Other Diesels:</i><br />1984 VW Rabbit 1.6L - normally aspirated
