Results 1 to 9 of 9
Thread: Gear Vendor Overdrive
    Sep 2003
    Kalamazoo, Michigan
    Have 4.10 gears ('95 C3500 w/ automatic) for towing........seems like a GV ovedrive would give one the best of both worlds....tow capacity AND good fuel economy. Any thoughts?
    2004 2500HD LT Duramax LLY+Allison 2WD Extended Cab SB
    Cooper LTX265/75R16 tires
    Email vernj4@juno.com
    britannic Guest
    They're great units, but expensive, unless you can find a secondhand one. Which transmission do you currrently have?
    Sep 2003
    Kalamazoo, Michigan
    Got the -80..........seems to work well. Will be looking into installing the switch to activate the the torque convertor lockup...seems like it would be good when coming down a steep hill.
    britannic Guest
    If "-80" means the 4L-80E, then you have a very strong tranny with a .75 OD ratio. The Gear Vendors may be overkill, since you already have an OD. I have the 700R4 with 4.56 diffs and find the rpms with 33" tires aren't bad at all at freeway speeds.
    Heartbeat Hauler Guest
    I don't think the GV is overkill on the 4L80E for this reason. When I had my '94 CC dually, I was told not to tow in overdrive. This means that you are going to be towing in 3rd(1:1), with 4.10s the motor is turning some rpms(3061 w/31.5in. tires @ 70mph). With the GV, you are actually driving in 3rd overdrive which equates to 3.12(2330 w/31.5in tires @ 70mph). This is almost what the tranny overdrive is and you don't have the wear&tear on that clutch pack, not to mention less trans heat. Then when you are running solo you will have 4th overdrive (dbl OD) with a final drive of 2.40. I agree, they are expensive at $2200 + 4-500 bucks install.
    JP
    JP
    Aug 2003
    Indiana
    Vernj4, I know what you mean about towing with the same setup. I use OD otherwise I would be pretty much limited to 55mph on interstates in 3rd. I have heard many state that you have a higher trans temp by towing in OD and heat is the killer of a transmission. I don't notice much of a difference in temps while towing my travel trailer in OD or 3rd. If anything I would say under most conditions where OD can be used my trans runs cooler in OD.
    A GV would be nice, but in a $5000 truck and driving about 10,000 miles per year I just couldn't justify one. You would have to burn quite a bit of fuel to make the GV worth your while.
    93 Crew Cab Dually 6.5TD cooling mods 4L80E trans temp gauge 4:10 227,700 miles<br />2002 Terry 30S<br />1980 Viking 160 S.S.
    moondoggie Guest
    Good Day!
    You may want to look at What's your fuel mileage with a load?
    Blessings!
    Brian Johnson, #5044
    LanduytG Guest
    I have had a GV in my 95 with 4:10 for about 4 years now and love it. I always tow in OD and the trans has 160K on it and works like it was new. I also tow in double OD when pulling my car hauler. Before doing this I would get about 12mpg and running double OD I get about 14.5 plus egt's drop way down and everything is much happier. GV says not to pull in double OD but with 4:10 if you look you will see that pulling in double OD is about the same as a truck with 3:45 pulling in regualr OD. Running empty I went from 16 mpg to 18 mpg. Also whats nice is the noise reduction. Though its expensive I love and would not trade it.
    Greg
    Dec 2001
    Temecula,CA USA
    I towed many miles in OD in my old truck, never had a problem. The key is as soon as the tranny starts hunting gears pull it into 3rd. I had over 120k when I sold it, original tranny, nothing done but oil changes. John
    83 K-20 8600 GVW, NA 6.2 \"J\", T-400, New interior, 2.5\" lift, 33X12.50X16.5, 3\" Dual Exhaust, AmsOil Dual Stage Air Filter, Lots More!!! FOR SALE!!! robertsonthego at msn dot com
