Which way round is your oil pan sump? Is your truck lifted? I didn't have to loosen the axle or remove the balancer during the pilot install to drop in the 5.9L CTD.
I have the rear sump configuration, so it's about the same position as the 6.2L.
I'm not using the original 1994-1998 motor mounts, but instead have installed purpose built mounts from AutoWorld in MT (great shop with excellent aftercare assistance). These make full use of the height in my engine bay and keep everything clear.
[ 04-22-2004, 06:20 AM: Message edited by: britannic ]
