Results 1 to 14 of 14
Thread: D MAX HP & TRQ
    Jan 2006
    MO
    Question
    WHAT KIND OF HP & TRQ NUMBERS ARE BEING MADE FROM THE LB7? BIG NUMBERS 700HP+?? WITH WHAT COMBO ??
    John Kennedy's 2002 dyno'ed 725 hp & 1373 tq last September on Edge Products dyno. JK will have to let you in on his secrets.. [img]smile.gif[/img]
    I've heard of some being close to 800 hp....
    BMDMAX Guest
    Reckon this is close enough?
    We had a run go 835 on my truck that day too.
    Jan 2006
    MO
    THATS IMPRESIVE NUMBERS. IT SOUNDS LIKE JOHN K KNOWS HIS STUFF. HAS ANY ONE MADE INTERAL MODS SUCH AS CAM, PISTONS HEAD WORK??
    BMDMAX Guest
    Aftermarket cams are just now coming available for the Duramax. No heads or pistons are really available yet but there are several companies with some skunk work projects going on.
    Jan 2006
    MO
    THANKS FOR THE REPLY. WHO IS MAKEING THE CAM & HOW CAN I GET ONE?
    BMDMAX Guest
    http://www.compcams.com/information/...ID=-1783812385
    I don't know of anyone that has verified any results or even is running one yet.
    madmatt Guest
    Hey BMDMAX have you studded your heads down yet? We were making BIG noumbers w/ our 02' till it started pukin' pistons. Have you experienced any catastrophic engine failures?
    BMDMAX Guest
    Nope, no studs and no failures. Hopefully I will stay lucky and keep it that way.
    Muscle Shoals, AL
    hey bmd, what are those controls on your steering wheel next to the center pad? radio? how did you do that if it is?
    BMDMAX Guest
    Those are the steering wheel audio controls off of the Escalade. It is pretty much a direct hookup to add them.
    I got the kit to do it at jpcustoms.com.
    Tough Guy Guest
    Thats impressive Brandon !!
    Kennedy Guest
    We should be pushing Brandon's LLY HP and TQ numbers up a bit next weekend!
    Jim Brzozowski Guest
    Hey John, if you'd move your shop to Texas, Brandon wouldn't have to drive so far. If I ever win the lottery I'm going to get you to set up my shop.
