<a href="http://www.thedieselpage.com/reviews/checkmate.htm" target="_blank">Checker Products
Fiberglass Tonneau </a>
The growing popularity of the pickup truck for use as a family rig has created both a need and a market for products that increase versatility. Tonneau covers are a popular product that add considerable lockable and dry storage space in the pickup bed. If you are sport truck oriented, you may want to consider a fiberglass tonneau like the one offered by Checker Products.
<a href="http://www.thedieselpage.com/reviews/pmdisolatorr.htm" target="_blank">PMD Isolator
Improving Reliability for GM's Electronic 6.5TD</a>
Helping the Pump Mounted Driver module reject heat can improve reliability. The Heath Diesel PMD Isolator is a remote pump mounted (PMD/FSD) driver and cooler assembly that was designed to effectively dissipate the heat generated by the module during operation.
<a href="http://www.thedieselpage.com/reviews/rogerstory.htm" target="_blank">1996-99 6.5TD Power Mods
Max-E-Tork PCM & Turbo-Master </a>
The 6.5 Turbo Diesel is a fine engine for everyday driving in stock trim, but put an 8500-lb trailer behind it, and you'll wish for more power. More power generally means more fuel and more boost pressure. To get more fuel and boost, you'll need to look at products that were designed for the model year of your vehicle.
<a href="http://www.thedieselpage.com/reviews/bighead.htm" target="_blank">Banks Big Head
More Boost for the LB7 Duramax 6600 </a>
The key ingredients to more turbodiesel power are more fuel and higher boost pressures. The Banks Big Head incorporates an adjustable turbo wastegate linkage, allowing you to raise boost pressure to get that power increase.
