Page 5 of 5 FirstFirst 12345
Results 81 to 87 of 87
Thread: High Miles Contest!
  1. #81
    Mar 2012
    The Catskills, NY
    244,000 miles on my beast, a '96 GMC K2500 only thing changed out on motor was injectors at 240,000 miles first time, oil pressure switch and obviously a PMD. I also changed the turbo to larger freer flowing one cause the gm turbos are junk and most likely would have killed my motor by now cause of high drive pressure. Im basically running an all original motor.
    For piece of mind im soon gonna swap out the harmonic damper and crank pulley and possible timing set
  2. #82
    Oct 2011
    Ft Walton Bch,Fl
    '95 K1500 274,700 new engine @240300...lots of repairs replacements...but still churning!
  3. #83
    Oct 2011
    Collingswood NJ
    Default high drive pressure
    What is "high drive pressure", that you refered to with the stock GM Turbo?
  4. #84
    Oct 2014
    Fraser Valley, BC, Canada
    Default The old gal
    1994 6.5td in a K3500
    She started her life out hauling freight from the West Coast to the East Coast doing weekly rounders.
    Today she is my daily driver (usually), still well taken care of (probably better than the wife- could be why I am divorced too).
    1,330,000 km's and still going strong
    If it fit in the bed, the wife would sleep in the garage :P
    1994 K3500 Dually
    1.3 Million and still going (usually)
  5. #85
    Aug 2001
    newark, de, usa
    Smile 466,543 miles 1996 suburban
    Have 466,543 miles on original engine, no engine repairs other than ipump, injectors etc.. Runs great, burns 1qt every 2500 miles. Still getting 18 on highway at 80.
  6. #86
    Oct 2011
    Collingswood NJ
    Default 18 mpg at 80 mph!
    18 mpg at 80 mph!
    What is your axle ratio?
    1999 Chevy Suburban LT 2500 4x4
    Stock 6.5 With 4'' Exhaust, 149,500 Miles
    Axle ratio, had 4:10, Now 3:42 posi rear
  7. #87
    My rig turned 300K this morning:
    No real major problems at all. Just normal stuff like several FSD's, one injection pump, alternator, A/C compressor, couple of starters, etc. Never touched the engine internals or even had to replace a glow plug yet.
    I've owned the rig since 174K were on the clock. I think it had one injection pump during that time as well.
