I just installed a Juice/Attitude on an 05 LLY. The truck responded well to the upgrade and runs excellent. The boost runs about 21psi. Thus far, we have no codes and the injector balance rates are in check! Next step...AFE Stage 2.
TJ
TJ
I have seen boost as high as 32psi with the boost stick added. Truck seems to like it OK. It seems to have increased performance quite well in every day driving and towing as well. Smile facter . No power adders added as of yet. Getting ready to order the Diablo here soon. Do get what is called turbo bark every now and then but JK said to take it in and have GM do an update for intake pop. Oh yeah take boost stick off before going in. JD
05 D/A CC LB LT SRW 4X4 Dark Gray Metallic -- Amsoil 2 stage air filter -- Amsoil 15w40 Oil--Amsoil Dual Remote Bypass Oil Filter -- Banks Monster Exhaust -- Amp Research Power Steps -- Prodigy---XM Radio -- HiJacker 21K 5er Hitch -- Primo Spray Bed Liner -- 05 Grand Juction 4 slides 39ft 5er -- Honey Keep It Under 15,500 Please
I have three friends with 05 LLY's and all have the Diablo Predator....My LB7 friends mostly have the Juice/Attitude.
I think the Edge is a sweet set-up because of the features, and install is a breeze.
I will soon be installing a boost stick on one of the 05 LLY's.
Chris
1999 F-250 PowerStroke Crew Cab Short Box Lariat 4X4
Fumoto, Turbo-Master, MBRP 4", Billet Triple Disc TC, HD TransGo Tugger, AIS, Triple Pod, Autometer Phantoms, SPDiesel Overboost Eliminator, SCT Tuned By Tadd @ Elite Diesel Performance 75/100/125 and DP-Tuner 80 Econo PCM, Sirius Radio...
2006 Jeep Liberty CRD Sport 4X4
Stock for now...
My Gallery
TJ
I wouldn't waste your money on the AFE kit(s) as it does very little unless you are running BIG power. I have seen a few LLY's with them and I had one on my '01 Dmax. A Foam filter (UNI) will be the best bang for the $$$. Although, the factory paper filters the dirt the best. With the LLY turbo you can electronically command boost (EFILive and Boost stick)unlike the LB7 motors. I have the factory paper still. I did do Kennedy's air box mod. It is on his website under "tech tips". www.kennedydiesel.com
I may go to the Uni air filter sometime if the GMT 900s look like the Tahoes/Subs. There side body lines look really sissy. I like the front look but not the sloping hood
Buck,
I think air flow in and out is extremely important. I use the Stage 2 on my dad's mod'd 03 Cummins and would have nothing different. The one I purchased for my 6.5L, now, that's a different story. I do believe their kit with the Proguard 7 is about the best you can get....
TJ
Folks - I traded my 02 in on an 06 (had to have the six-speed!) and have a juice/attitude with pyro probe (already had one hooked to a Ispro guage) that I'll let go for a reasonalbe price. I recieved it in Aug 05 (shipping papers to prove what I say - was running the Juice by itself before then) so it's very new. If $500 sounds reasonable, give me a call (478)3354394 (Georgia). If not, let's talk as I sure hate to see it go to waste.
By the way - the 06 is a totally different truck and I can't imagine what JK has in store for it. Great power right out of the box!
DMAX #4 2006 D/A 3500 LT Long Bed 4X4 - They just keep getting better!<br />#3 2003 D/A 2500 LT Short Bed 4X4 (for the wife)<br />#2 2002 D/A 3500 LT Long Bed 4X2<br />#1 2001 D/A 2500 LS Long Bed 4X2
TJ,
You are correct, the flow rate of air is the key to lower EGT's and complete combustion, which means you got all your moneys worth (BTU's) out of the fuel burned. DO NOT buy an intake for HP, buy it for flow and EGT reduction. If you add fuel you need air, no two ways around that to get good combustion.
I am a big beleiver in the PG7, stops the dirt within 1/2 of 1% as well as a paper filter but still flows the air. Stay away from the 4 layer filters on a diesel, too much dirt intrusion. Call us if you have any questions etc.
Mark @ DPPI
DIESEL PERFORMANCE PARTS INC. 1-866-455-7788 www.DIESELPERFORMANCEPARTS.COM WE GUARANTEE OUR PRICES, PERIOD! MBRP EXHAUST SYSTEMS, EDGE PRODUCTS, SMARTY, AUTO METER GAUGES and MOUNTS, DiPRICOL GAUGES, SUPER CHIPS MICRO TUNERS, DIABLO PREDATOR PROGRAMMERS, AFE INTAKE & EXHAUST SYSTEMS, PML ALUMINUM TRANS PANS and DIFF COVERS, VAN AAKEN PERFORMANCE MODULES, TS PERFORMANCE, POWERSLTO ROTORS, HAWK BRAKE PADS, FASS SYSTEMS by DPP, SUNCOAST TRANSMISSIONS, BOSCH INJECTION SNOW WATER METHANOL SYSTEMS, BULLY DOG PRODUCTS, ARP Studs, FLUIDAMPR, STANADYNE ADDITIVES.
Mark,
My thoughts exactly!
