Results 1 to 6 of 6
Thread: Autometer and Banks six gun
    May 2003
    Hayward, CA
    Default Autometer and Banks six gun
    Okay what am I doing wrong here? I know not too many of you are Banks fans, but that aside. I have a set of carbon fiber autometer gauges, boost and EGT, but now that I have the Six gun and do not see a way to hook everything up together without having to run 2 thermocouples? I know Banks says there branded EGT gauge plugs right in to the six gun, but I don't want to have to change all my gauges. Can anyone help? There was one thought of running 2 lead wires off one thermocouple, but where do I get that second lead wire?
    Nov 2000
    Hamilton, Montana USA
    Default Gauges!
    Quote Originally Posted by DieselDixon
    I really think the Banks Six Gun and SpeedLoader is a nice set-up and makes great power...
    Do you have to use the Banks pyro at all? If so then, I would use the Autometer pyro also....Then if you ever do use something else for power increases, your all set...
    Chris
    1999 F-250 PowerStroke Crew Cab Short Box Lariat 4X4
    Fumoto, Turbo-Master, MBRP 4", Billet Triple Disc TC, HD TransGo Tugger, AIS, Triple Pod, Autometer Phantoms, SPDiesel Overboost Eliminator, SCT Tuned By Tadd @ Elite Diesel Performance 75/100/125 and DP-Tuner 80 Econo PCM, Sirius Radio...
    2006 Jeep Liberty CRD Sport 4X4
    Stock for now...
    My Gallery
    May 2003
    Hayward, CA
    Well I hooked up the six gun today without the speed loader. Still trying to figure out what to do, looks like I either have to run 2 thermocouples in the manifold, or buy the banks pyrometer gauge?
    Jul 2005
    Portland, OR
    run 2 pyros. one in each manifold. you can get a BD manifold for the drivers side with a thermo hole already drilled and tapped for $300
    Dec 2004
    Texas
    Don't try to hook additional wires to the thermocouple, its readings are based on differential voltage readings taken from the existing wires inside the unit. Do anything other than hook it up and you will change the reading.
    May 2003
    Hayward, CA
    Quote Originally Posted by SoTxPollock
    Well after talking to Banks other then hooking up 2 thermocouples they said that I can run 2 wires off of the same thermocouple. He did mention that it would give me a false reading but he said it won't be off enough to make much of a difference. I've had the gauge hooked up for over a year now and a week with the six gun hooked up. I should be able to see a difference at this point if it is noticeable, I will just run another thermocouple.
