1. What model do you drive Truck Shortbed, Truck Extended Cab, Suburban, Tahoe, Other (Specify): 1994 pickup shortbed extended cab empty load
2. Level 1500
3. 4x4
4. Driving Habits; 2
5. Tune of vehicle; 3
6. Fuel additive added every fillup in OZ; PS 4 oz's
7. Size of fuel tank 25 Gal.
8. Rear Gear Size (3.23, 3.55, 4.10, ect):3.73
9. Tire Size (ex; 245/75 R16): 245/75 R16
10. Tread style; Mud/Snow
11. Gear vendor? (if so, od/ud ratio and how you use it): None
12. Boost control; Mechanical/Electrical: Factory
13. Boost pressure setting (4-20lbs): factory
14. Manual/Automatic Trans: Auto
15. Thermostat (160, 180, 190, 195, 205, 215, none): 195
16. PCM programming (Heath 1.0, 2.0, Kennedy 72/76/max, Westers): Factory
17. Timing Gear Y/N: STOCK
18. Intercoooled Y/N: STOCK
19. Mist injection Y/N: STOCK
20. Air filter (stock, stock w/ airbox mods, stock airbox with special filter, both, 97 and newer box, cone filter): STOCK AIRBOX with hole cut in the top of the box.
21. EGR/Non EGR: Non EGR 1 ton intake manifold
22. GM Turbo Style (GM5,6,8, other): 1994 STOCK
23. Exhaust (Stock, mufff removed, kitty removed, 3", 3.5", 4", other) STOCK
24. TDC offset set to (stock, or the value you have it set to):STOCK? don't know, rattles really loud at idle
25. Stock injectors/High pop: STOCK
26. Synthetic oil Y/N: YES, Rotella 5W-40
27. Highway mileage (not towing, best averaged over 3 tanks): 19.5MPG @ 75MPH, 21.2MPG @ 65MPH, 16.5MPG average city
28. When mileage data was obtained (Winter, Summer): Summer/ Winter is aprox. 2MPG less in all above conditions
29. Approx miles on vehicle:200K
