Results 1 to 7 of 7
Thread: Bio Diesel
    Manitowoc,WI, USA
    Thumbs up Bio Diesel
    Does anyone use biodiesel in their Diesel PU? Or how about " Diesel Secret Energy" additve for veggie oil? I'm seriously thinking of producing my own fuel..............gofaspilot
    97 K2500 Ext.cab SB,5spd W/4.10 ,166000 miles, 4 inch exhaust, intake mods.
    Aug 2005
    Talent, Oregon
    I have been running about 20% bio on average. I get it 3 miles down the road for $3.25. I have run up to about 80% last summer (when bio was cheaper then #2 for a while). I have had no problems and have not noticed any real changes in performance negative or positive.
    Adam
    Adam
    95 K2500 extended cab/longbed 142K 4L80E 4.10 Gears
    Bumper mounted FSD, Autometer pro-lite Boost/EGT/Trans
    Jardine 4" exhaust/ Afe Pro Guard 7 Air Filter
    Intercooler http://rides.webshots.com/album/546682061RucHxo
    Oct 2003
    Huntington In
    Thumbs down
    Quote Originally Posted by gofastpilot
    Do you know what goes into making this DSE work?
    Biodiesel is our furture
    95C3500.Ext.Cab 97 Cooling mods. DSG Gear-1.95 TDCO. Bilstein Shocks. Firestone Air Bags. FSD Cooler. Banks EX System. Egt,Boost & IAT Gauges. JK High Flow/pop Injectors. Turbo-Master. Max-E 2.0. Water/Alky Injection. Amsoil Dual Bypass. Baldwin filter. aFe Air filter, Air box & Turbo Mods. Power Service Product. Large Duels 235/85-16. Tool Box\'s & truck, 8200 lbs.
    Concord, NC, USA
    I'm very close to getting my biodiesel processor up and running. There are many who are running the stuff in their GM's. Here's some links to learn more:
    http://www.biodieselcommunity.org/appleseedprocessor/
    http://biodiesel.infopop.cc/6/ubb.x?a=cfrm&s=447609751
    Concerning the "secret", buyer beware: http://biodiesel.infopop.cc/groupee/...4511077101/p/1
    Mark Chapman DP member #653;
    "Grease is good"
    Dec 2004
    Arizona
    I run 100% homebrew. Its soooo nice passing the diesel stations. Kinda wierd how its been so long since I have used good ole dino....I kinda miss it, but $80 per week was crazy.
    I run a semi unique bio making process. I took extra steps and measures to make it user friendly and as automated as possible. Time is money for me and I dont want to be spending time makin diesel. I am using the "appleseed" type processor with a few of my own improvements.
    We have a family coop because most of my family drives diesels. I make approx. 300 gal. per month ( could do more, but currently limited by WVO supply). And everyone contributes in one way or another. My wife can go out and do a titration, open a few valves, and set a timer and walk away.....20 min. tops. Then, 24 hours later, open a valve, drain the crap, and transfer the bio in a wash tank and set another timer and walk away. Plus, while one batch is washing, another batch is processing. Soon as I get time, I will take pictures if anyone is interested.
    BTW, I highly recommend buying the book "Biodesel Homebrew Guide" by Maria Alavert. http://www.localb100.com/book.html
    But dont let it scare you...she gets real "overwhelming" but in reality, its a quite simple process.
    My truck runs well on the stuff and we currently use Bio in D-max's, Cummins ISB and cat and case equipment.
    Do not get into the "magic snake oil".....I just dont think its that easy..IMHO.
    Good luck.
    SOLD:2001 GMC LB7, ZF6, SouthBend SMF single disk, Hypertech tow tune, 4x4 crewcabLB. Shaeffers diesel treat every tank... 125,000+miles on original injectors.
    1989 1 ton dually flatbed. 6.2, GM4 turbo, TH400, Flatbed. I Paid $200 for it 5 years ago and I drive it like a rental ca r everyday....undergoing NV4500 soon.
    Couple diesel Suburbans
    Nov 2003
    Davenport Florida
    Talking
    What is the main ingrediant in your bio ?? Whatcha cookin ???
    email rfkjr@juno.com
    07 2500HD C/C LBZ 248k
    My dad and I have been running B80 to B100 since we started up our own biodiesel processor last September. We're running in it my three vehicles and Dad's Power Stroke. It's great. We used the 'appleseed' processor mentioned above.
