Thread: Cummins Conversion Update
    grandjunction,co.usa
    Talking Cummins Conversion Update
    Left with the 5th wheel on spring break for Canyon Lands in Utah. Drove all the same hills Im used to driving and watching the temp. gauge rise quickly and praying the fan-clutch comes on in time to avoid melt down. ha ha.
    This time the fan clutch was never needed and the temp. gauge moved one click on the biggest hills. Thought I was dreaming and didnt want to wake up.
    Truly a pleasure to pull again. It will take some time for the old temp. fear to go away after years of fighting it. Been driving 6.5s since 1994.
    I didnt check the mpg, but seemed about the same when pulling hard as the 6.5, just had more power and cool temps.
    The 6.5 smoked less ( wife doesnt like smell of diesel ) but once your moving its all the same.
    Hope all of you are enjoying the spring time and day light savings time!!!!
    Dan
    1997 CCAB DUALLY WITH 1997 CUMMINS CONVERSION
    2006 CHRYSLER 300C HEMI AWD
    1996 LT1 ROADMASTER
    1969 HURSTOLDS
    1964 POLARA 500,BUILT 440
    1970 DART,BUILT 318
    GOD, FAMILY, COUNTRY, DOGS
    16gaSxS is offline Moderator, Have Shotgun & dogs will travel
    May 2002
    Great Falls, MT
    Dan;
    Gled your happy with your new set up. Sounds like you had good trip.
    95, 6.5, C-2500 extended cab shortbox, Auto transmixer 3.42 diff, Jardine exhaust system
    FSD Cooler replaced w/ Heath PMD Isolator
    Heath Turbo-Master Boost Controller, Max E Tork chip '97 cooling upgrades, Kennedy Fan clutch,
    Glow Plug over ride,DeeZee 38.5 gallon Aux fuel Tank 225K miles and rolling
    1994, 6.5 Blazer, 3:42 diff, 4 inch exhaust, Heath PMD Isolator, Heath Turbo-Master Boost Controller Max E Tork, Heath SB intake filter system.
    221K miles and rolling.
    Diesel Page member #81
    Jul 2003
    Last summer in 112 degree heat, I took my Dodge Cummins with my 5th wheel up the Grapevine on I-5 in Ca (6% grade). I had to slow down from 75 to 65 because it started to get hotter than I liked. It really takes alot more to heat up a Cummins then a 6.5. Dan I am glad that your conversion turned out great.
    97 6.5 Turbo Diesel Suburban 1500 - 95 Dodge Cummins Turbo Diesel 2500
