Results 1 to 6 of 6
Thread: Anybody Know What A Cummins 5.9L Weighs?
    Feb 2006
    Minnesota
    Default Anybody Know What A Cummins 5.9L Weighs?
    Hello All-
    Does anyone know how much a Cummins 5.9L weighs? I saw a swap done in a Chevy pick-up where he pulled the 6.5L and put in the 5.9L. The article said he would be getting new leaf springs in the future to compensate but they never said how much more it actually weighed.
    -AFK
    Do a search for "moedog cummins" - he swapped to a Cummins recently and had Autoworld do the work.
    16gaSxS is offline Moderator, Have Shotgun & dogs will travel
    May 2002
    Great Falls, MT
    Quote Originally Posted by trbankii
    I asked Ken from Auto World about it while Moedog's truck was being done, and he said the there was only about 150 lbs difference and not too big of an issue.
    95, 6.5, C-2500 extended cab shortbox, Auto transmixer 3.42 diff, Jardine exhaust system
    FSD Cooler replaced w/ Heath PMD Isolator
    Heath Turbo-Master Boost Controller, Max E Tork chip '97 cooling upgrades, Kennedy Fan clutch,
    Glow Plug over ride,DeeZee 38.5 gallon Aux fuel Tank 225K miles and rolling
    1994, 6.5 Blazer, 3:42 diff, 4 inch exhaust, Heath PMD Isolator, Heath Turbo-Master Boost Controller Max E Tork, Heath SB intake filter system.
    221K miles and rolling.
    Diesel Page member #81
    Sep 2003
    Feeniks, Aridzona
    According to the company that shipped my 6.5, a long block with timing cover, IP, lines, and injectors weighed in at 685, and that was with the wood crate it was strapped to. That is less than 700 lbs...
    Default cummins is 436 kg or 961 lbs
    I don't know if that's dry or not but I found it here page 3 table 3
    http://homepages.cae.wisc.edu/~vehic...itechpaper.pdf
