Results 1 to 13 of 13
Thread: Please help me diagnose what the problem is
    Dec 2005
    Calgary, Alberta - Canada
    Angry Please help me diagnose what the problem is
    Hello,
    I have a 1995 K2500 Extra Heavy Duty with the L65 engine option, 6.5l turbo diesel.
    Recently while driving the truck, I have noticed that the accelerator doesn't always respond like it should. ie. you are driving along, truck is running fine. You take your foot off of the accelerator, slow down, then go to accelerate and there is no response. If you really push your foot into it, it will then leap back to life.
    At the same time, I was driving along, only to get the "Service throttle soon" light up. In a couple of cases, the truck has gone into a limp mode of staying stuck at 1000 RPM regardless of how far I try to push the accelerator.
    If I turn the truck off, it always restarts and then sometimes the "Service throttle soon" light will not appear and the truck will run fine for a while, only to reapeat the accelerator and "Service throttle soon" nonsense.
    Recently, I disconnected the batteries, let the truck sit for a while and re-connected the batteries. The truck ran fine for quite some time and ran very smooth.
    Only to find this morning, soon after I started it up, this nonsense came back of the "Service throttle soon" light and going into this 1000 rpm nonsense.
    So, I took my Jeep to work instead.
    I haven't tried to find a Diagnostic Trouble Code as of yet, but plan to.
    Also, 7000 km ago, I replaced the PCM on the injector pump and it has run fine until this other nonsense appeared.
    Worse yet, I just had some work done on the front end, ie. brakes and other stuff.
    Any suggestions?
    Thank you to anyone that responsds.
    2Lane
    First thing to do is read the stored codes.
    My guess is that "Service Throttle Soon" is more than just nonsense...
    Quote Originally Posted by JohnC
    X2! It seems to me that your truck is doing its best to tell you what the problem is...
    Diesel Page Member #2423
    Dec 2005
    Angry Thanks...
    Point well taken, it is probably not nonsense. However, there has been times when the vehicle has given false readings. One tends to feel that it is crying wolf sometimes.
    What is meant by "Service throttle soon?" What is involved - assuming that there is no false readings.
    Thanks.
    May 2004
    Salem, Oregon
    2Lane,
    I had this same problem too, after a pump/pmd was replaced by the dealer.
    Definately go down to Autozone or your local parts store that has a scanner. Get the code so that you know.
    But, also check your grounds!!! My grounds that go to a stud on the intake manifold back by # 8 cylinder had loosened up-big time. Once I tightened my problems went away (9months)- I also has some other symptons as it would die and the Service Throttle light came on...my volt meter, oil pressure gauge were behaving erratically.
    Bad grounds will do crazy things...check them before you start chasing parts.
    Brent
    BrentN
    1999 Suburban 2500 4x4
    176,500 miles,4.10,K & N Air Filter
    Kennedy 3.5" Exhaust, Remote Mounted FSD Cooler
    Kennedy Boost Fooler, Homemade Intercooler (Dieselpage Model)
    Derale Fan Cooled Tranny Cooler (under body mount)
    A Pillar Pod (Isspro Boost, Pyro & Trans Temp)
    2014 Cruze 2.0 Diesel- Tuned and loving it.
    Kerma TDI Tune (+35hp/75lb-ft).
    55.7 MPG best average thus far
    2008 Grand Cherokee, 3.0L Mercedes Diesel
    Tuned- 240hp/440lbs - Amazing out of a 3.0L
    1998 Dutch Star 38' Diesel Pusher, 8.3 Cummins, Allison 6 spd, 9.9-10 mpg
    Stock 300 hp/850 ft-lbs
    If you do replace the throttle assembly, (your footfeed is basically a spring loaded, electric potentiometer) call the parts yard. New ones are $300. Used can be found for $50.
    Aug 2003
    Winnipeg, Manitoba Canada
    And since you are in Canada, a new APP module can be had for slightly more than 300 dollars.
    I was quoted 670.
    But as suggested already, read your codes, if you have a GM service manual the procedure is in there, and quite simple with OBD 1.
    With key in off position, connect the top right two pins of the diagnostic plug (under the dash up around your left knee when you are seated in the driver seat) with a paper clip or other suitable wire, and turn key to "run" (don't crank engine) and count the flashes of the SES light.
    Be ready with a pen and paper and record the flashes.
    Each series will flash 3 times, with a little longer pause between first and second digits, example, code 33 would be "flash flash flash" pause "flash flash flash" (and over again twice before on the next code).
    And since APP module are so expensive, they are worth trying to salvage the existing one, if at all possible.
    I'll try and see if I can find a previous post on a possible repair, and edit to include in this post.
    From reading the information on these boards the last few years, the APP module seldom fail, but anything can. Electrical gremlins can pop up at any time, and can often be repaired by simply unplugging and re-seating electrical contacts, and regular maintenance of battery connections and associated grounds and such.
    Edit: tried search feature, appears as though I can only search back a few months, and two searches using identical keywords net two different results.
    At any rate, the procedure (initially posted by Chevdooley) you can try if it is established the APP module is the culprit is to carefully drill a small hole in the plastic cap on the end, spray in contact cleaner, swoosh around and drain and dry out as best you can, plug the hole with silicone or such, and try again.
    It has worked for some.
    1994 K1500 Silverado ext cab short box
    stock L56 6.5 TD, F intake, 4L80E, 3.73 gears
    10149599 block, D-Tech PMD on 5288 pump
    Goodyear Wrangler silent armour 265 75 R16 E Pro Grade
    Bushwacker fender flares
    410,000 km
    The throttle assembly has 3 tps units that all work together.
    The computer needs to see the same reading from all of them within a certain allowance.
    If one dissagrees then the code will set, if 2 are hinky then the computer sets the limp mode.
    Beings this is a fly by wire system they have to have a safety to prevent a runaway condition.
    Get the code and most likely you will just need to replace the TPS unit.
    Good luck
    Robyn
    Dec 2002
    Long Island, N.Y.
    The Chevydooly TPS/APP [AcceleratorPedalPosition/ThrottlePositionSensor] service procedure referenced by C-H-Bob will at least help in troubleshooting. Grounds and batt cabling is good initial service (after codereading).
    The PCM[PowertrainControlModule] is in/behind/over the glovebox. It has multiple functions (CPU+) including directing engine operation after incorporating sensor input, like APP and ECT and boost.
    The PMD/FSD[PumpMountedDriver/FuelSolenoidDriver] comes OEM screwed onto side of FuelInjectionPump. It energizes the solenoid-valve on the FIP that squirts pulses of diesel fuel down the injector lines.
    The codes are your friend... happy motoring!
    tom m
    '95 6.5td 4L80E 3500/srw p/u
