Results 1 to 20 of 138
Thread: Is it worth changing gears for better MPG's???
    Apr 2004
    Palm Beach, Florida
    Default Had My 3.42's For Awhile Now
    After all is said and done I admit I would have saved $$$$.+ dollars not changing out gears on my 4x4 burb to 3.42's from 4.10's.
    Been through 2 sets of GoodYear MTR's stock and 285's great of road but a waste on road. Now using 285 GoodYears SilentArmor like the quiet sure footed ride on road and they work good in sand.
    MPG is not consistant unless I drive at slower speeds, but I'm now geared for 70+ mph and the drag is a drag.........................
    I'm actually thinking seriously about going back to 4.10's maybe 4.58's w/taller tires................
    Feb 2002
    Maine/Florida
    I doubt your TCC is ever locked...
    1996 K3500 EX-CAB 108K MILES
    MODS:UnderDASH PMD,38G Aux Tank
    ISSOPRO BOOST&EGT,Fuel Pres Gage
    CSI Oil & Trns Temp Gages
    BD DOWNPIPE, Rem Oil Filter
    Dual inline LP/Filter SOLD AT 130K MILES, Know GM LESS
    Apr 2004
    Palm Beach, Florida
    Default Going Back To The 4.10's
    Been mulling this around for some time now and decided to go back to the 4.10's.
    Will have the 3.42's on the market soon, frt 9.25" ring w/pinion, rear 10.5" ring w/pinion.............
    Feb 2002
    Maine/Florida
    try the resister to fool the tcc lock up, stay in 3rd gear, tcc should stay locked above 45 mph, don't use 4th on a hill, down shift manuel...
    2nd gear will also lock tcc about 32 mph...
    but you have to shift manuelly, as Trans will be in high pressure mode,
    Need to shift like it's a std shift, un-throttle and match rpm to drivetrain.
    I installed a sw for the TCC lock up, and a sw for the 3-4 shift,
    2 sw's by the console to control shifting...
    Apr 2004
    Palm Beach, Florida
    Question NEED Resistor info
    Quote Originally Posted by rjwest
    I'd like to try this, what's involved?
    Feb 2002
    Maine/Florida
    50 ohm resister accross the tran emp sensor to ground, through a switch.
    this will allow the TCC to lock up at 40 mph for a 3.73 gears,
    allow 2nd to lock the tcc at 28 mph for 3.73 gears.
    4th , mph not affected,(abot 50 mph tcc lock up)
    But the TCC will not unlock, will hold untill down shift , ( very harsh shift ) thats why you need to manually shift,,,
    Note all all your speeds will be about 10 per cent higher, with the 3.56
    ( there are posts on the resister. ).....
    for the 3-4 gear shift, need a switch in one of the 3 shift control lines,
    that go to the trans,leave in 4th, open switch and it will downshift to 3, close for upshift.
    I will have to look in my manuel to find which wire it is, will get back to you,
    Note: if you forget and leave in 4th lock out ( 3rd gear, sw open )
    and restart engine, a code sets that makes a harsh shift,,,
    I was working on a 2-3-4 shift box, with a lock out relay, to prevent
    the code problem but sold the truck.
    If you have a code reader, setting code is not a problem as a code clear resets it.
    will get back with more info..
    Jun 2006
    St. Albans, WV
    Default Confused, need help
    I have read most (if not all) of this thread, but I am still a bit confused.
    I just swapped out my 4.10s in the Burb for some 3.73s. I rarely tow and never very heavy. I was looking for some lower revs on the interstate and my rear end needed rebuilt anyways.
    I checked my speed with a handheld GPS and it appears as though I am actually going about 3-5 mph faster then my speedo claims.
    Do I need to "Hack the VSSB"? Or, maybe get a signal modifyer to hack the VSS? I'd like to have my speedo be more accurate and I'd like to have the TC lockup a little sooner (for economy if possible). What should I do? What's the best compramise?
    Any advice/help would be appreciated.
    Thanks!!
    96 Suburban K2500 6.5L TD. High miles and daily driven (for now). Remote mount FSD with cooler, Turbo Master/Boost fooler, 4" Jardine turbo back exhaust, 2.5" cross-over pipe, Boost, EGT, & Tranny temp gauges, working on more.
    Hacking the VSSB can correct the speedometer. The TCC lockup is based on engine speed (torque) not road speed. No easy way to hack it and it probably isn't a great idea. If you did hack it you'd want it to lock up earlier only under very light load conditions, which may result in it going in and out of lock annoyingly often...
    Jun 2006
    St. Albans, WV
    See? I am confused.
    So, is hacking the VSSB the best (maybe easiest/cheapest) route?
    Jul 2007
    S/E Michigan
    I'm new here and tried to read through this thread before asking...I recently picked up a "95 3500 HD 2WD dually w/19.5s that has a 4L80 and a Dana 80 rear diff. that according to the tag it is 4.63 and noticed everyone else seems to have 3.42,3.73,or 4.10. It needs a rebuilt 6.5L and wasn't running when I bought it, so I have no idea how it is at highway speed or the mileage. I'm in the process of building a dump bed for it, and it won't see speeds above 55mph very often and will be used to tow on occasion. Does this sound like the correct ratio for this truck and it's intended use? I apologize if this is a dumb question, but I'm new to all of this... /// tim
    1998 VW 1.9L TDI 190K d/d 47-50 mpg
    1995 C3500 HD dually 6.5L TD 4L80
    1972 C20 3/4 ton (possible conversion)
    1948 Farmall H (still gas, but I did read about a neat conversion using a '68 Mecedes diesel engine... )
    Jul 2007
    ortonville, mi
    for that diameter tire, sounds right
    http://www.thedieselpageforums.com/tdpforum/image.php
    07 GMC CC SB LBZ
    70 monte carlo, original 4 spd, bench seat
    71 monte carlo SS clone, street/strip
    97 grand am, beater
    Hacking the VSSB is the way to correct the speedometer. The TCC lockup speed is best left alone.
