Results 1 to 10 of 10
Thread: MAX HP & FT/lbs
    Jun 2006
    Richmond UT
    Default MAX HP & FT/lbs
    Quick question: Out of curiousity what is the most HP or torque that you quy's have heard of someone getting out of a 6.5L TD? Are any of you guys over 350HP, or is that just way off the radar? Not that I'm planning a huge buildup or anything. I just haven't heard anything other than the factory rated 190HP. Thanks for any input
    95 K2500 Silverado regcab, 6.5L F-vin, 4l80E, HD alloys 3" turbo back, Air intake, custom machined FSD isolator & I just turned over 50,000 original miles SOLD!!!
    79 Toyota Hilux 20R, G52 5-speed swap, 4.7:1 t-case gear reduction, 4.37:1 R&P's, and 35" X-terrains. Too bad the poor thing is about to die from skin cancer
    86 F250 Lariat 4x4 6.9 diesel, 4 speed, 3.55 gears, and lovin it
    Peninsular sells 400 HP models in a box.
    Want more than that? Check THIS out. (or THIS if you have dial up) Those Euro's are nuts. Twin turbos AND twin pumps!
    Apr 2004
    Palm Beach, Florida
    Default Bigger issue
    Keeping it cooled down....
    Quote Originally Posted by DA BIG ONE
    VERY big issue. Problem is, most folks try big mods with stock cooling, then complain about that POS so and so.... Keep temps under control and you can get away with just about anything. It's always been that way. "Marine" parts generally do mean more power, but the designers assume your cooling system is measured in acre/feet, or square miles, not gallons or liters.
    Jun 2006
    Richmond UT
    WOW! I can't imagine 2 IP's & twin turbos! That was really cool thanks. It seams like (aside from small things) that cooling and compression are the 2 limiting factors on a 6.5L. I hope this is not the last of the reply's to this tread Keep em' coming!
    Compression ratios and heat come hand in hand.
    Jun 2006
    Richmond UT
    Quote Originally Posted by DmaxMaverick
    True very true
    Nov 2002
    Martinsville, IN
    Read the article in Part I in my signature. The numbers will be better soon!
    Mar 2005
    Bremerton, WA
    I saw where he plumbed the h2o injection. I did not see a thermostat in his coolant crossover pipe. I would venture to guess that his setup is making around 700hp and 1400 ft/lb of trq. From the sound of his run, I believe he is spinning well past 3200 rpms. Probably 5000 rpm or more.
    The ultimate power display from a 6.5L. I want one too.......
    -*og%rice*-
    93 C3500 dually 6.5td. 18.7:1, Balanced, Coated, Underdriven, BD 4" exh, Turbomaster, 2 gage pillar + 3 gage dash, Dual electric fans, DB2 4911(maxxed out), NV4500, Propane, 97' cooling, Pre luber aux oiling, Phaser timing gears, hand made glow plug wiring harness 10ga. fluidampr damper, two pass FMIC, more to come..............
    Jun 2006
    Richmond UT
    Quote Originally Posted by ronniejoe
    There is a proxy that pops up when I try the link . Is there anywhere else I can check it out I'm very interested?
