Clarification
Pardon, a little comment here.
Actually it would be more proper to say that on the Ford 9 inch and perhaps the 1150 in question, a bearing was not moved to the other side of the pinion, as the two main cone style bearings still are on the outboard side of the pinion and there cage a crush sleeve that determines preload and a third needle roller bearing that provides additional support was added to the inboard end of the pinion. And yes, it is a much more substantial design.
95 GMC C2500, 449,000 miles, 4L80E w/ 4.11, 4 inch exhaust, gauges, OPS relay mod, Cold start & Fast Idle controls, 18-1, PMD cooler, coolant updates, cam gear drive, Chinese HX35W clone., Kennedy Max Effort chip
