Originally Posted by
trbankii
Haven't been able to get back to this. Last week the job hit me with working seven days a week for the next month or more... Which is a whole 'nuther hassle...
Might have to look at the SnapOn puller, though. I have the Kent Moore puller and there is no way to get the steering box to move far enough to get the puller on. Although, the other item added to the mix is the snow plow mount. Maybe that is interfering with things if I'd try to pull the box forward... I've tried turning the box clockwise, so the shaft points towards the engine but that doesn't give enough clearance.
I just used a standard puller and almost didn't need it AFTER getting the steering box out on the tail gate (work bench). I thought it was going to be a chore to get the box out of the frame, but it's not all that bad. You can probably have it all done in an hour or so.
-Patrick Henry
A5150nut
2006 K3500 D/A
94 6.5 4x4 5spd Sold
