To avoid surge the twins must be small, however, you can use a smaller turbo on your motor then go with another turbo about twice the size for a compound setup. This will yield higher boost levels at low boost setting and at much cooler charge temps with charge cooler (IC) it would rock......
See:http://www.turbomaster.info/eng/bulletins.php?id=18
