Results 1 to 16 of 16
Thread: Left side mounted Turbo?? For Australian Conversion
    Sep 2006
    Question Left side mounted Turbo?? For Australian Conversion
    G'day,
    I've just bought a 6.2 for a project vehicle and a turbo is definatly required.
    I'm searching for a Banks type 'kit' that mounts the turbo on the left side of the engine bay Anyone seen one??
    The right side has the diff, propshaft and brake booster to snake around (yep, it's right hand drive - I'm Australian). Left side will be easier and neater to package.
    Might have to fab up a set of extractors if there is nothing available.
    Cheers,
    Brad.
    Aug 2003
    Bakersfield, Ca
    Brad,
    Welcome to the Page. Lots of knowledge in here.
    Don't know if there are left side turbo systems available. That doesn't mean there might not be. We have a number of members that hail from down your way. Perhaps they will chime in.
    HammerWerf
    1999 k2500 Suburban Pyro, Tranny Temp, Boost, K&N Air Filter, +3.5 qt tranny pan. 190000 miles
    1984 C20 249k miles DSG gear, SM-465, 3.73
    1983 C30 CC dualie. 308K miles on Chassis, TH400, 4-45 A/C Looking for a TurboCharger
    Aug 2000
    Riverside, CA USA
    Have never seen a left size single turbo for the 6.2/6.5. Lots of right side manifords for them.
    83 C10 Suburban, Silverado, 6.2, 700R4, 3.73, 31-10.50R15
    82 C30 Crew Cab dually, 6.2, Banks, Th400, 4.10, Gear Vendors, 235-85R16
    83 C20 Suburban, Sierra Classic, 6.2, 700R4, 4.10, custom paint, 285-50R20
    95 Yukon, 6.5, 4L80E, 3.42, 265-50R20
    73 GMC Astro 95, 8V71, 10 speed Roadranger, 110" WB, 6 each 11R24.5
    Sep 2001
    Lubbock TX, USA
    This could get creative!
    One thing (I haven't even looked to see if it's possible yet) is take a 6.5 turbo manifold and install it on the US driver's side (cylinders 1-7) and run your crossover pipe on the front of the engine. Sames goes for the other side, figure out which manifold will mount backwards on the other side.
    It's gonna be custom fer sure.
    J
    Aug 2000
    Riverside, CA USA
    In looking thru other messages in this forum saw just what you were talking about. Penninsular Diesel has a twin turbo for the 6.5 diesel. More Power has posted a photo of it. This is typically for a marine diesel, but could easily be used for our trucks. As always watch out for cooling. The marine diesel gets the benefit of water cooling while our trucks use the relitively ineficient air cooling intercoolers.
    Aug 2003
    Bakersfield, Ca
    http://www.thedieselpage.com/archive.htm
    'Brad,
    One of our members in the Neatherlands built a twin turbo setup for his ex US Army Blazer. The above link will take you to the article archive. It is the last one (at the bottom of the page). This will give you some ideas.
    HammerWerf
    Sep 2006
    Default Thanks blokes,
    Thanks boys,
    A mate at work had that idea today at work, use the same manifolds but use them on the other head. That'd work fine (in my head at least).
    Keep the hot turbine to the back exhaust take off in the right direction and rotate the outlet, cross over pipe under the front.
    Looks like thats the plan.
    Aug 2000
    Riverside, CA USA
    The manifold from Peninsular appears to use equal length tubes for the header. That is probably better than the stock manifold with all 4 inlets going to one pipe.
    St. George, Utah.
    Talking
    Ozbrad:
    There is a fellow in Austrailia that does GM diesel conversions to fords and the like. His name is Leo Wignell.
    I contacted Jim (More Power) and he has the information that you need to get in contact with him. I know that he has manufactured his own left side manifolds, I have seen pictures.
    Contact Jim with a PM and he will fix you up. Good luck and welcome to the Diesel Page.
    Denny
    2018 GMC Denali HD 2500 L5P.
    Sep 2006
    Default thanks
    Leo Wignall is based in Euroa, he must be the bloke dad mentioned that we would go check out.
    All sorted.
    St. George, Utah.
    Glad to be of help. I got to get down under and see your wonderful country sometime.
    Good Luck.
    Denny
    Apr 2002
    Fairbanks AK.
    There is a member named noelb, from Australia, that has a 98 Suburban, that is right hand drive, you might want to ask him how his turbo is set up. I have seen a picture of the right hand drive suburban, and it looked like it had a center mount turbo like the hummers, but I could be wrong.
    Bryan
    1999 Chevy Suburban 2500 4x4 H2 Wheels and tires
    1984 Chevy Blazer 6.2l with timing gear set
    Jul 2002
    Michigan
    Smile
    I believe noelb's rig has a center mount turbo like the hummers and vans have. Could be wrong though.
    Mar 2002
    The Netherlands
    Funny, I did not know my article was still on the page!
    Any way, it's not that hard to fab manifolds, I used a solid plate to bols it up to the heads and that gave me some trouble with the glowplugs and the heads are not flat so I had to grind them to fix that.
    Some body I know http://www.thedieselpage.com/readers/kolkman.htm made a very cool set of stainless headers with just the four plates at the ports like it's supposed to be.
    Just take your time and step by step you can build your own custom headers and put the turbo were ever you like
    Good luck, Peter
    '85 CUCV blazer 6.2 twin turbo diesel (300 HP ), 4L80E with PCS trans controller '64 F350 tow truck (restoration project)
  15. #15
    Jun 2003
    Pretoria South Africa
    Peter
    Could you perhaps get a detail picture from Arjan Kolkman to see how each exhaust port "T" into the manifold. Do you know if it's at a right angle or does it join in with a bend to ease the flow?
    Danie
    1982 Blazer ("Ratau" ROAR OFF THE BIG LION in African Tswana language.) 6.2L N/A, 700R4, 3.08 gears, 33" BF's. DSG timing gears, 12" Donaldson air filter, J intake and dual 2.5" exhaust. The rest stock.
  16. #16
    Mar 2002
    The Netherlands
    Danie,
    from what I can see on the pic's I have, there are bended pipes going up from the ports and T straight into the monifold, both manifolds are flushed together under the turbo.
    So the manifold construction is kinda simmilar to my manifolds.
    Peter
