Gear splitter
The 700 r4 widebox can be built to withstand the 6.5td even when modified. So, a gear venders setup would multiply gears x2, and other gear splitters can be adapted too.
The 4L80e goes x2 w/gear venders too and keeps the automatic shifting.
http://www.transmissioncenter.net/4L80E.htm
