Results 1 to 2 of 2
Thread: Rear axle swap
    Oct 2004
    Long Island, NY
    Default Rear axle swap
    I have an 8 lug 14 bolt semi floater axle assy in my burb. I would like to swap it out for one with disk brakes. Can I do it? If so what year(s) can I use. Other than master cyl what else would I have to change?
    99 GMC 1500 Suburban SLT 6.5TD F eng, 4X4, 4L80E, NVG246, 3.42, bst, egt, Pinnacle 4" exhaust, 327k miles
    Here is an article on converting a 14B to disc brakes. I think you need to start with a FF rather than SF, though. My understanding is that the FF will swap right in place of the SF.
    Disclaimer: Watch where you tread around Pirate. The Tech area is fairly tame but wandering into the forums could wound you if you aren't prepared for it - not as clean and kind as this forum!
