Results 1 to 2 of 2
Thread: 14 bolt spindle
    Aug 2003
    Panama City Fl
    Question 14 bolt spindle
    Recently the 14 bolt full floater in my dually ate an outer spindle bearing. Long story short, the bearing went, froze up and the resulting damage broke the nut that holds the axle in. Axle almost departed the housing, while moving. The problem I now have is that the spingle is slightly out of round and cannot get the nut back on. Is there a away to re-round the spindle. I have tried thread files, a small triangle file to restore the roundness with no luck. If I cant get the nut back on, I have to swap the rear end. Does anybody know the thread size on the spindle, or know of some sort of fix?!?!? I need some help!
    I have picture of it, but it is too big to post.
    1994 Dana 70 HD 4.11 Dually Crew cab. Exhaust work, 249,996 miles on orginal motor. Zero miles on new one.... Gauge work and various custom mods. Bumper & manifold (spare) mounted FSD cooler. This thing must have been assembeled on a Wednesday!!
    Apr 2004
    Palm Beach, Florida
    Thumbs up 14 Bolt data
    Go to this site look up in tech section "14 Bolt Bible" lots of data and tech manual downloads too.
    http://www.pirate4x4.com/
    Good luck
