Thread: Thinking of going to a cummins conversion
    Apr 2004
    Palm Beach, Florida
    Default Thinking of going to a cummins conversion
    Been researching and found the 6L Dodge Cummins Turbo bolts up to most GM trannies. I need input from those who are in the know on best way to intergrate this motor into a late 90's GMC 4wd burb. I'm considering a stand alone tranny controller and will not need the GM 6.5td ecm w/conversion.
    I already have a great running recently rebuilt 94 6L turbo cummins motor.
    Any thoughts?
    Oct 2002
    USA
    Smile
    I think it is longer and heavier than the GM mills and maybe the radiator might have to be moved forwad, but I'm sure someone has done one. Sounds like a fun project.
    0000000
    Apr 2004
    Palm Beach, Florida
    Default Perhaps a HUMMER 6500
    Stuffing the cummins in a late model GM may not be worth the effort since I read herein about a HUMMER 6500.
    I'll use the cummins in something else maybe in a much older dodge, or GM product.
