Results 1 to 10 of 10
Thread: Freeze plugs on front of Block above cam
    Apr 2005
    Mesa, AZ
    Default Freeze plugs on front of Block above cam
    Does anyone know what size the freeze plugs should be that go in the front of the block above the cam? Is 16.2 mm the right size?
    Thanks,
    Kyle
    '83 Blazer, DB2 built like 4911 by Accurate Diesel, 6.5 oil pump, 6.5 turbo injectors, 82 6.2 block, 6.5 heads, serpentine, gm-4 turbo with turbo master, timing gears, custom stud girdle, lower compression
    Pics: http://s153.photobucket.com/albums/s205/kkarlson_photo/
    Those holes are oil galleries that feed the lifters and run from front to back on both side of the cam. ( Both front and back should be screw in type plugs.
    The front ones are recessed to clear the cam gear) The other two holes above the cam are left open for oil drain back from the lifter chamber.
    Hope this helps
    Yes, don't forget those plugs! If you don't plug those oil galley holes now, you won't have any oil pressure when you start the engine up! (Don't ask me how I know!)
    Apr 2005
    Mesa, AZ
    My front ones are not pipe plugs. They are just recessed holes. I bought 16.2mm freeze plugs that fit tightly so I will just use those. I just wanted to know if they were the right size.
    Yeah, they're just the drive-in style plugs. That's what makes them easy to forget. Without those plugs in place, the oil gets pumped up from the pan, through the camshaft galley, and then dumps out the front of the block back into the pan.
    Lubbock TX, USA
    Hmm, I can't recall the size, have to go look through the photo gallery and see...
    All 6.2's and most 6.5's use the press-in plugs in this area.
    The later 141 and 506 casting 6.5's have the pipe plugs (better idea IMHO).
    I see what I can do, I think mine were standard...
    1986 C10 SCLWB 6.2TD 3.73 700
    1989 V20 SUB 6.2NA, 3.73 400
    1994 G20 VAN 6.5NA, 3.42 60E
    1996 K30 DRW 6.5TD 4.10 80E
    Sep 2009
    or.
    Default freeze plug under rear main cap
    Can someone please tell me if and where the freeze plug under the rear main cap goes. Thanks
    '94 K2500 6.5 ,maxitorq chip, 4" exhaust, turbomaster, pillar gauges, rear air bags.
    '95 k3500 6.5 project.CC SRW
    Under the rear main cap ????
    The only soft plugs in the back of the block would be the end plug on the cam bore.
    The lifter oil galleries have pipe plugs in the back and soft plugs up front untill later 6.5's then screw in plugs.
    Explain more about "UNDER THE REAR MAIN"
    Missy
    rogers's Avatar
    rogers is offline Where there's smoke.... There's fire!
    Jun 2009
    Juneau, Alaska
    I think reddog is talking about this thread. I admit I read it the other day and ever since I have been a little paranoid myself. I just rebuilt my engine and I don't remember this plug. Anyone got a picture?
    1996 GMC K3500 Crew Cab Dually 8ft bed
    Rebuilt engine 2/10 18:1 pistons, forged crank, Fluidamper, dsg gear drive timing, high flow oil pump, rebuilt GM8, turbomaster, Kennedy ECM, 4" exhaust, wrapped cross-over and down pipe, '98+ cooling, Duramax fan, aftermarket oil cooler and hoses
    Rebuilt tranny 2/10
    The plug in question is the MAIN GALLEY plug and is driven into a hole in the block under the rear main cap.
    I have a bare block sitting in the shop and will get a piccy here in a while and post it up here.
    Missy
