Results 1 to 20 of 23
Thread: Adding BTU to Diesel fuel
Hybrid View
    Jan 2005
    L.I. NY>
    I dump a Qt. of any thing I can pick up cheap. 10-40, 30wt or 2cycle. every time I top off. But still use Stanadyne blue or Howes all year.If the Motor oil gets to concentrated I can smell it in the exhaust and I skip a dose. The oil is mainly for peace of mind for lubeing the pump. If you want to see what extra BTU's can do for your truck, chuck in some Home Heating oil and boost the cetane. Your truck will love it.
    Dave
    99 sub 2500, 326,000mi, 4:10, 265-75-16 rubber, remote Dtech fsd and turbo master from Heath Isspro pyrometer and boost gauge-Kennedy, 1.94 TDCO, 3" custom bent exh.
    07 Suburban,08 LMM, Allison 6 speed.
    Jul 2006
    Hudson, WI
    Quote Originally Posted by Dave NY
    Dave
    Home heating oil? how much? Currently I add Diesel Power Service "Diesel Kleen + Cetane boost"
    James
    Jan 2005
    L.I. NY>
    I have run on #2 for mos at a time usually during boating season, truck and the Cats in the boat like it very much. You just have to treat the fuel with cetane boost. I treat 275 gal with a 2 qt jug of Stanadyne Blue. Dave
    Sep 2006
    Brooker, FL
    Home heating oil is basically the very same as diesel (#2 fuel oil) - there is no advantage with using home heating oil , except the possibility of enriching one's attorney, since it's illegal (no road fuel tax, and likely not a legal formulation with respect to sulfur).
    Anyway, the "octane rating" is based on the performance of a motor fuels as compared to isooctane (100) versus normal heptane (0), and it's a measure of how quickly the fuel-air mixture will combust.
    Cetane rating is essentially the time-delay from injection to ignition of the fuel-air mixture. Cetane-improver is unnecessary for a diesel designed to run on 40 cetane.
    Adding motor oil to diesel fuel is unwise, since all the components don't burn; ashless 2-cycle oil is OK, but I use FPPF or CRC additives rather than 2-cycle oil.
    Adding gasoline is also not just unwise but dangerous. The diesel-gaso mixture will now have the flash/fire point of gaso - and damage to the engine is quite possible (ever notice the prohibition against using ether to start a glow-plug equipped engine?). The gaso will also defeat the addition of lubricating additves to the diesel.
    Jul 2006
    Hudson, WI
    Quote Originally Posted by rustyk
    sorry...but what is FPPF and CRC? (newbie to diesel stuff)
    James
    Jan 2005
    L.I. NY>
    It is a common mistake to confuse off road (500ppm) diesel with Home heating oil they are very different with respect to sulfer and lubricating properties Which result in a higher BTU per Gal than on and off road fuel which are identical to each other except for the red dye for tax purposes.Just take a piece of clean wood and spill an ounce of each and see which one is still there after a couple of hours. As far as supporting my attny maybe we all better put the cats back on and yank the ecm's out before the boogie man gets us
    Dave
