Home heating oil is basically the very same as diesel (#2 fuel oil) - there is no advantage with using home heating oil , except the possibility of enriching one's attorney, since it's illegal (no road fuel tax, and likely not a legal formulation with respect to sulfur).
Anyway, the "octane rating" is based on the performance of a motor fuels as compared to isooctane (100) versus normal heptane (0), and it's a measure of how quickly the fuel-air mixture will combust.
Cetane rating is essentially the time-delay from injection to ignition of the fuel-air mixture. Cetane-improver is unnecessary for a diesel designed to run on 40 cetane.
Adding motor oil to diesel fuel is unwise, since all the components don't burn; ashless 2-cycle oil is OK, but I use FPPF or CRC additives rather than 2-cycle oil.
Adding gasoline is also not just unwise but dangerous. The diesel-gaso mixture will now have the flash/fire point of gaso - and damage to the engine is quite possible (ever notice the prohibition against using ether to start a glow-plug equipped engine?). The gaso will also defeat the addition of lubricating additves to the diesel.
