Results 1 to 9 of 9
Thread: 95 6.5L K2500 4x4 what kind of rear diff?
    Dec 2006
    NJ
    Default 95 6.5L K2500 4x4 what kind of rear diff?
    I was wondering what kind of rear diff is in my stock 95 6.5L 2500 Sierra 4x4 because I've been looking at the HD2500 trucks and they come with a posi rear. Not sure if mine is just a regular open diff or if its some sort of weak limited slip. can anybody tell me. what kind of options do i have for making it a posi rear? make just get the diff from a newer 2500 HP truck and make it work with the right gear ratio
    95 GMC Sierra 2500 4x4 6.5L turbo ext cab 6ft bed ( relocated NEW PMD with cooler, running so far so good) SOLD SOLD SOLD
    95 Chevy Silverado 1500 4x4 Z71 stepside 350V8
    Jan 2003
    Old Line State
    Do you have 6 or 8 lugs(14-bolt semi-floating)?There were light and heavy 2500s.If 8,does the rear hub stick out like a front hub on the old-style 4wds(14-bolt full-floating)?It cold be open or could be the Gov-Loc,as limited-slip/locking diff.
    aka:Tim
    `91 V2500 Scottsdale Suburban:6.2 4L80E 4"Lift 35s
    `92 K3500 SLE SRW:Peninsular6.5TD Peninsular 5spd
    `72 K20 CustomDeluxe Highlander CustomCamper
    `72 K20 CheyenneSuper CustomCamper
    `72 K2500 SierraGrande
    `71 K10 CustomDeluxe 6' Fleetside
    Dec 2006
    NJ
    6 lugs, i'm guessing its the open diff and nothing sticking out
    Brighton, CO, USA
    Default Look at your RPO codes...
    Being a 6 lug, you have a semi-floater, but could still have a locker.
    For the locker, the easiest way to tell is to look up your codes on the glovebox sticker. Look for a code "G80" - this indicates you have the factory locking differential. You can also tell gear ratio, GT4=3.73, GT5=4.10, GU6=3.42, etc.
    Also, I'm not sure the newer HD trucks automatically come with a locker, just seems that most are equipped that way.
    Hope that helps.
    Joe.
    2006 Chevy K2500 LLY Duramax/Allison Crew Cab!
    1996 Chevy C2500 6.5 auto Ext. Cab LB
    Jun 2006
    St. Albans, WV
    Huh.....
    It's a 3/4 ton (2500), right? I thought 3/4 tons were 8 lug, and I thought all the diesel trucks were 8 lug. I guess I was wrong??
    Quote Originally Posted by Shikaroka
    Huh.....
    LD (Light Duty) is 7200# GVWR, and semi-floater 6 lug r/e. Also equipped with the same smog as the 1/2 tons in most states.
    HD (Heavy Duty) is 8600# GVWR, and full floater 8 lug r/e.
    However, I've seen factory LD's with 8 lug full floaters, too, with no rhyme or reason for it, and the same RPO's as the LD's.
    2500 Suburbans were all 8600 GVWR.
    Jul 2001
    Windsor, Colorado, USA
    And just to cause further confustication 1500 Suburbans with 6.5 Diesel engines had 8 lug wheels and the semi-floater 9.25" 14-bolt.
    2002 GMC Sierra 2500HD CC D/ZF SB Fire Red 2WD no longer the fastest stocker up the hill at the TDP Pull Off. -sold-
    2004 Chevy Suburban 5.3L 2WD
    1996 GMC Sierra 1500 5.0L 5sp 2WD LB
    Dec 2006
    NJ
    yea it is confusing as i thought all the 2500 and up trucks had 8 lug. when i got this is was very surprised, i just sold my gas with a 6 lug with new tires on AR wheels that I could have used. oh well, i'll check the glove box codes and see. I see GT4 which i guess means my gear ratio is 3.73. Rear is 14 bolt. Is that any good with the 305/70/17 in tires that I have on? No code for a limited slip, I guess might just be the standard crappy rear. Any idea what to look for if i go to a junkyard like in gas and diesel trucks to find a factory locker or posi rear? http://www.jegs.com/webapp/wcs/store...0002_750876_-1 found this Eaton LSD for 497$, looks like it should be the right one, do these trucks have 33 spline axles? Also is PowerTrax which is a locker type set up that fits and is about 470$?
    Jun 2006
    St. Albans, WV
    I should have known it was not so cut-and-dry.
