I thought the link was pretty good and does support at least a little credibility for different injectors for the "marine" application. 6.5 pressures are a lot lower and IDI is a different animal but I think the link does show fair comparison for nozzle size. It references penetration rate of fuel and flame front into cylinder. I did not see any documentation of any power differences but does show there is a difference in spray pattern/combustion to nozzle size.
It has always struck me that marine injectors/nozzles are OE name brand parts at least from all the reading I think they are OE for marine applications. We are not talking some joe injector shop marketing his modified injector. Is the HP rating of marine engines higher? I have assumed they are and thought the pump was turned up and engine set for more HP since adequate cooling could be guaranteed with the application. Combined with the fact economy is less of a concern with recreational applications and emission requirements are different too.
Like posted earlier several times it does not make sense to me that just changing injectors will give any appreciable HP gain. But after viewing link I think it can definately be argued injector differences can be matched for application ie I think marine injectors are better for steady hi RPM operation and or maybe higher fuel delivery. And then maybe not necessairly for anything other than better emissions. HP gains are probably due to IP fuel delivery increase only.
