Lonnie Diers Extreme Automatics
1994 Chev 2500HD 532,119 miles 21,300 GCW towing machine.
Original engine, injectors, replaced head gasket 1 injection pump, 3 turbos
Ready to install ( was ready now changing to 18.1 pistons)
New engine 4 bolt splayed steel caps
Lightly ported heads
Polished intake port matched
HX35W Turbo
Intercooler (very efficient tube fin design)
Marine Injectors hi pop
Cooling upgrades
3" DP
4"exhaust
remote mount PMD cooler
Fresh air intake (in the making)
Gears ???? have not decided looks like 3.42
250HP at the wheels or bust (maybe both)
The end caps 1 and 5 are very strong as they are fastened to the ends of the block where there is massive amounts of material and the girdle bars tie the whole lot together.
The best way of course is to do the complete girdle with the cross bolts and anchor everything along the way.
This simple tie bar is still a very worthwhile addition to any 6.5.
One thing that is absolutely a step in the right direction is to lightly chamfer the bolt holes in the block on all the mains especially the center ones.
The ragged sharp edges in the block are a perfect send off to getting cracks started down the outer bolt holes..
All really great stuff in this thread. Good tech and a step in the right direction.
Robyn
In all the pictures posted in the thread (oil in the coolant) all the cracks seen to follow corners in the machine work ie. the piston bore. Robin is rigth that a sharp corner will not stand the pressure of a radius corner. The stress is spread over a larger area. All we can do is try to lessen the damage by rounding and bracing. Blazin has some personal value due to time spent with my son. So it is worth it to me to try. Question: Is the pattern on the mains the same on a 6.2l and a 6.5l?
1982 K5 Blazer(Blazin) 4x4, 700r4, start of modified exhaust, 6 inch tall filter breather with 4" snorkel,egt gage, main bearing girdle as seen in gridle thread
1985 Suburban(Labrat) 4x4, 3' dual exhaust, egt gage, opened intake,700r4 with alto clutches, beast sun shell,13 vane pump,and more,others in progress hence the name.
I would really like to have more information about the roller rockers shown
Which parts were used?
What machine work do I have to do?
Anyone know where to get this info??
1991 CK2500, 6.2 banks turbo, FourtGear built TH700R4, Dick Cepek 6.5" lift, 35" wheels
Jesel roller rockers were used. The original mounts on the head need to be machined flat to accept the Jesel rocker bases.
The valve covers need to be modified to accept the increased height of the rocker adjusters - or do as Andrew did, and machine a 1/4" aluminum spacer to raise the covers (fits between the covers and the heads).
Thanks for the info, but more specific which Jesel rockers?
Yes , to machine an aluminium spacer would defenetly be the way to go.
Would it be possible to get in touch with Andrew?
Sorry to be bugging you about this but....
I had a look at the Jesel web page and couldn't find any rockers that looked like the ones used so I asked Jesels tech help to identify them. Answer is that this is not a Jesel rocker setup.
What could it be??
Is the stud girdle still performing well? Did you make or are you making kits for sale. I can build my own but if someone has already done it and it works why rock the boat?
