what was wrong with them?Originally Posted by Mark Rinker
Michael 04.5 SRW LLY
custom stock intake, upsized boost tubes, Pre-turbo WMI, EFILive custom tune, Aerotech Scan Gauges.
Go Smokeless!
Don't have details from previous owners, just the service history from VIN searches. It would appear both died from prolonged towing while overheated. Turbos, pistons, etc. C4500s are rarely used as daily drivers. Always towing/hauling at higher RPMs due to lower gear ratios.
Personally, I am shopping for LB7s only. Can't take a risk on getting someone else's overheated problem. It seems like there are lots of '05 C4500s for sale, more than any other model year out there...
Ok, this may not be your answer but I ran across this and it may help someone.
Cold start, both t-stats closed, coolant pumps to oil filter-flywheel houseing cross over-block-heads-EGR and heater core @ 26GPM. Engines warms to 180* first stage of the primary t-stat allowing some flow to the radiator. At 185* secondary t-stat starts to open flowing more to the radiator. In here @ arond 132* the turbo starts recieveing coolant through a thermo controlled circuit by-pass. At 203* the primary stat is full open. At 212* the seconday stat is full open, all coolant is through radiator and flow is near 80 GPM. Now this is for the LLY engine. bob.............
Bob O.
off-topic. It is odd that the turbo cooling begins so late. I would guess that it is important that the turbo not be thermally shocked. This was a real concern in turbocharged Cessnas, there were air cooled.
Go Smokeless!
I do not profess to be knowledgeable in engine technology, but I would expect that running a Diesel at high hp output (towing) with a leaking headgasket would very quickly blow or melt a bigger hole through there, and start warping head or block beyond repair.
Can't imagine it'll get you very far once that starts to happen, and could leave you stranded with little warning, or lead to engine on fire.
If you know which cylinder is low on compression, and you want to squeeze a few more miles out of it, what would it cost to have a small shop install a new gasket just on the one side only?
2005 Chev K3500 SRW Dmax Allison Ext Long Box
