Anyone have access to a good pictorial of the Duramax cooling system, showing thermostats, pump, radiator, etc and detailing coolant flow? If so, could you scan and post it - or email it to mark_rinker@hotmail.com?
Thanks in advance...
Coolant travels from the water pump to the engine oil cooler, into the aluminum bellhousing adapter, into both cylinder banks at the back of the engine, then up into the heads, then to the thermostat housing.
Contact Me
Content Web Site
Photo Album
TDP Youtube Channel - New!
Thanks for the description, JK.
You have mentioned in a past that one of the reasons for two thermostats is redundancy.
Are they 'serial' in their restriction of coolant flow, or 'parallel'?
parallel, and staggered by 5 degrees. One of them is a bypass stat. When it "opens" it closes off bypass flow.
If you squeeze your top hose, you will hear a rattling sound. This is the vapor purge mechanism "jiggly balls" in the rear stat.
Interesting. Is there a safegaurd to keep the two from being installed reversed?
My '01 pressurizes the cooling system, but only in cold weather (bypass mode?). Wondering what the effect of removing one or both thermostats would be and continuing to run this high mile engine for another 50K or so, and repowering in the fall before cold weather sets in, creating the coolant loss issue described in other threads.
Would you pull one, or both?
The stats are physically different. Would be hard to install wrong....
In theory, if you pull one or both, then the lower rad hose would be subject to suction collapse at high rpm.Originally Posted by Mark Rinker
The front stat cannot be installed in the rear, but I do believe the rear will fit the front housing. If that were to occur (wrong stat in the front) then the bypass would never be closed off, radiator flow would be reduced, and overheat would be the result on a workload session.
But I can't see how running without a stat can be less stressful to a high mileage vehicle.
Michael 04.5 SRW LLY
Go Smokeless!
