Results 1 to 20 of 99
Thread: LMM Fuel Economy
    Jan 2007
    Somewhere between WI & WY
    Quote Originally Posted by 02bymorris View Post
    my 08 Silverado LTZ crew-short box LMM averaged 17.5 local driving. I swapped the ECM to a Kennedy custom and piced up 2 more mpg. have not tested it yet on a trip. all stock except for the ECM
    Even the exhaust system is still stock?
    08 Blue Granite Silverado LTZ, DMax/Ally, CC/LB/4x4, Cab lights, Camper mirrors, Brake controller, Sunroof, Park assist, and skinny tires
    06 Jetta TDI
    00 Jayco 263RK (2nd home)
    upgraded to an "09" Ranger 619VS/full windsheilds, w/an ETEC 225HO, T8 kicker, Minnkota 101 Terrova, and Lowrance electronics.
    Real Trucks have LONG BEDS!
    Jun 2005
    Iowa
    Towing I get 10-11 and thats towing heavy, gross wt of 19k +. Local driving I get 14 -15 and the dic is usually around 15.4. On a highway run with few starts and stops and keeping the speed at 55 - 60 it will do 19+. On the same run at 65 it knocks mileage down to 17. All hand calculated. I can usually tell a regen if I watch the dic because it will go down about 2 mpg from where it normally will be. My LLY would do a little better than the LMM, but not much. I like the truck.
    08 2500HD LMM D/A Ext cab sb LT1 4x4 Greystone Metallic. 265 75r 16 Mastercraft Courser C/T 10 ply's. B&W GN. Pull 20' STL Featherlite Combo trlr.
