Results 1 to 20 of 74
Thread: Billet & Forged Crankshafts
    Quote Originally Posted by gmctd
    Where you guys (and gal) seeing all this detail - all I ever get is great blank spaces with really huge letters to the effect of www.TheDieselPage.com
    i think this computer hates me...............
    If you are seeing that image, you are either not logged in, or are logged in using the incorrect URL/IP.
    Log off.
    Click www.thedieselpageforums.com/tdpforum and log in w/ your user/pass.
    If your login URL contains numbers, well.....there's your problem....
    If you are still not seeing the correct images, you have a browser security or cookie issue. No cookies, and you will loose your login priveleges in just a few minutes, even if it still shows you logged in.
    If you still can't get it, send me an email.
    robyn said: I too am currious as to why they did not cast the new blocks with a deep skirt and use cross bolted mains
    I've wondered the same thing.
    Here's a photo I took while visiting DMAX in 2001, showing the deep skirt design used in the Duramax 6600. Side captured main caps would be nice for the 6.5... Jim
    Very nice pix of the D Max
    I have owned two 427 Ford Side oilers in the 67 vintage and one 427 Cammer of the same erra.
    The side bolts have little spacers that are custom ground to fit exactly into a particular spot and are marked so they cant be mixed up. 2R- 2L 3R-3L and so on
    I have never seen the breakdown on the D MAX but I ussume they do something similar.
    With the crank all buttoned up with a deep skirt and tied into the rail its really tough to break them short of a catastrophic Kaboom.
    High nickel iron block thats cast plenty heavy.
    OMG we need to get the truck down to the spring shop and get the front end lifted out of the dirt.
    I would like to know more about the new block you have pictured though.
    I would bet the particulars are pretty well guarded right now too.
    Robyn
    Sep 2000
    usa
    That billet dipstick tube is absolutely the cat's meow.......
    If that 'girdle' is aluminum, looks like a fancy schmancy spacer to get around the real business at hand, across the mains-webbing inside, maybe with splayed outer bolts to get into the pan rails
    (Those angled areas appear to be within the arc of the rod-cap nuts, and would be necessary if that girdle extended inward of the oem pan-rails)
    They've plumbed the CDR back around to the oil fill tube, where there's less likely chance to pull raw oil thru at high cfm\Boost pressures - be an excellent arrangement for the current crop of 18:1 hi-po engines, or any performance upgrade, rather than have it plumbed to the street, as is common practice.
    That does indeed look like an electric fan clutch setup, and I like the dual t-stat rearrangement to afford more space for IP operations - but, it's prolly only to save money on that long upper rad hose.
    But, that's prolly also why they went back to the earlier accessory-mounting package - wouldn't have been room to move the t-stats forward with the late mounting arrangement.
    IMO, of course..............
    jd
    '96 Dodge 3500HD cc 2wd drw............'89 GMC 3500 cc 4wd drw
    5.9 12v #10TST 6sp SBC13-1.375.......6.5TD EFI maxEtorq v2.0 DSG
    DODGE makes it CUMMINS shakes it.....4L80E 205 4.10 Dana60\70HD
    6 in a row makes it go.......................Grandpa's big truck
    I would really like to get my tools on one of those engines and tear it down all the way.
    Fat chance of that happening in this lifetime me thinks
    I agree with you GMCTD on the nicks, bumps and bulges on that spacer under the block. There is definately something serious going on there.
    That little jewel did not come cheap and is certainly there for a good reason.
    Those angled areas very well may house a clearance slot for the rod nuts to swing through. Sure would like to see inside one.
    Knoxville,Tennessee
    Quote Originally Posted by robyn
    OMG, Robyn did you forget your WD40 and the sun came out? Looks like sunburn to me! Oh, I forgot you found the trick tools................
    I would like to see the inside of that motor too. But on my finances it would have to be here on this site.
    -Patrick Henry
    A5150nut
    2006 K3500 D/A
    94 6.5 4x4 5spd Sold
    Yup me too.
    My budgit allows for ebay junk and garage sale goodies.
    Oh and dont foget craigs list crap too
    My 91 Burb came off craigs list as did the Banks turbo setup and a few other piles of goodies I have stacked up.
    As far as the trick tools go. YESSSSSSSSSSSSS.
    Once the newness wears off though it will all be old hat and boring accept the smiles They are always good
    Robyn
    Nov 2001
    Aitkin, MN
    Good Day!
    "Thanks Ron
    After I asked the question I went poking around in the User CP and turned it on.
    Things are not safe now" Now if we can just get her to hit two spaces between sentences in the same paragraph, instead of "Enter"...
    Blessings!
    82 6.2NA K15 4X4 pickup, 4spd man w/ OD, 335K+ "In Rust We Trust" (parked)
    95 6.5TD 2500 4X4 pickup, Gear Vendors Aux. OD, > ¼ million miles - gone
    95 6.5TD 1500 4X4 3/4T Suburban, Kennedy exhaust, > ¼ million miles
    93 6.5TD 3500 4X4 1T crew cab LB pickup, 230k miles
    Ft Jackson, SC USA
    Get real I want it in my truck running!!!!
    Carey
    97 GMC K3500 6.5TD 4.10 CC SRW +259K miles; Kennedy Fan Clutch w/ 20" steel fan; Greg's Oil Cooler Lines; Racor 445 30 micron w/ heater pre-lift pump; Dr Lee By-pass Oil Filter; High Idle Switch; Revo 265/75/R16 Load Range E tires
    Sep 2001
    Lubbock TX, USA
    Back to 6.2, amazing.
    But... I like my non-epa friendly CDR vent (does one even need a CDR like this?).
    Glad you noticed too, guess I better get ready to polish another one...
    1986 C10 SCLWB 6.2TD 3.73 700
    1989 V20 SUB 6.2NA, 3.73 400
    1994 G20 VAN 6.5NA, 3.42 60E
    1996 K30 DRW 6.5TD 4.10 80E
    Sep 2000
    usa
    Wink
    Well - dogs like to 'mark' their territory every where they go - don't see much point in doing that with the 6.5, but if you like leaving spots every where over several hundred-k miles, then you prolly won't need the CDR system, with it's added weight and hi-maintenance aggravation, to prevent main-seal leaks, eh?
    jd
    Sep 2001
    Lubbock TX, USA
    It has stayed...
    The track owner might not appreciate my marking, actually already got in trouble for that once (diesel)
    Jun 2000
    Arlington,MA U.S.
    I have the hose from the CDR going under the truck and not in the intake like it was stock. It does not drip on the ground though. It leaves a little coating on the bottom of the truck but it's to prevent rust
