Results 1 to 11 of 11
Thread: 6.5TD NV4500 Conversion Info (and Parts) Needed
    Apr 2007
    West Michigan
    Default 6.5TD NV4500 Conversion Info (and Parts) Needed
    We are collecting all the items required to change out the 4L80E to an NV4500.
    With this operation, a new motor is being built with mechanical IP.
    Outside of the motor requirements, we have acquired most of the main components (trans/bell housing/clutch cylinders/etc.)
    Can anyone provide information on the following items as this transmission is applied to a 96' to 01' chassis ? The target vehicle is a 2000
    '96 c2500 Suburban 2wd
    All stock w/'97 Cooling, FSD Cooler
    '00 c3500 Base Truck 2wd
    Large exhaust, Jasper towing 4L80E
    Gauges, FSD Cooler, Bambygone lites
    Talking
    If you don't get the response you need here, try this link http://drivetrain.com/ I have talked to Dave at ext 144 IIRC. He seamed to realy know what was what with these transmisions and the provide any and all parts you might need. They ship quickly and their prices are good too!
    And NO, I don't work there. Only used their part and been happy with them. My brother got a conversion for his jeep from them too. Everything he needed was there and fit.
    AB Canada
    I am prob to far away [Nortern Alberta ] for you but i should have all the pieces you need out of a 95, don't know if it is all compateble though.
    98 GMC sierra 2500 ext cab 4x4 auto tr 6.5 td 252000 km. needs new engine, next project
    95 GMC sierra LE 2500 ext cab sh box 4x4 auto tr 6.5 td 328.000 km. my wife's truck .remote pmd on cooler
    89 GMC sierra SLE 1500 ext cab 4x4 auto tr 6.2 720000 km engine swap at 665000 km because of broken oil cooler line. 6 bolt wheels.
    Waldon wheelloader repowered with a 6.2 na
    Mar 2001
    Mission B.C. Canada
    Talking
    A couple of other places to check out for you;
    www.newventuregear.com
    www.JBConversions.com
    www.hig-impact.net
    www.advanceadapters.com
    For the single mass flywheel you will need (should get) a vibration dampner fo the output shaft. Also you didn't say where the NV4500 came from if it was a Chevy no problem, Dodge you will need another adaptor between the bellhousing and motor. The input and output shafts are a different size than Chevy's.
    Original D.P. Member #750, 2009 Ext Cab LB 4x4 Duramax/Allison, Black, Linex, 1993 6.5 TD 4x4 reg cab LB, 5 speed, 1972 Pontiac Lemans, 94 cady De Ville
    Apr 2007
    West Michigan
    Thanks for the response.
    Simon
    Formerly Scotland, Now Alberta, Canada
    Hi Simon,
    If Dawghauler is not interested in the 95 NV4500 parts could you email me, my address is
    jim at jimmyt dot plus dot com
    Let me know where in Alberta you are located
    Regards
    Aug 2006
    WV
    could a regular flywheel from another gm engine with the correct amout of teeth on the ring gear be used
    Shane
    AB Canada
    Quote Originally Posted by Chevrolet4x4s
    Shane
    You should check the numbers, they should at least be the same weight I think.
    Aug 2006
    WV
    so a flywheel from say a 350 would boltup and work fine if i used the crooect clutch for the flywheel?
    Shane
    May 2005
    SE Wisconsin
    Another source would be Quad4x4 or Novak.
    1997 GMC Savana - 6.5 TD
    1967 Jeepster - Stock
    1986 Jeep CJ7 - Stock
    Just wanted to say I've dealt with Dan at Quad4x4 and they've been most helpful.
