Results 1 to 7 of 7
Thread: 2002 duramax repeated injector problems
Hybrid View
    Apr 2007
    Angry 2002 duramax injector problems
    I've been buying fuel at the local fina station. I have added power service to my fuel in the past and just recently change to lucus. The service manager told me today that the 7 year 200,000 mile warranty was added only for the fuel system and that the customer relations guy that told me the warranty was for the entire engine was no longer employed and gave me the wrong info. So now my warranty will expire in August and I am wondering if running 100 miles loaded with about 50/50 diesel oil mixture in my crankcase has damaged something that may show up six months down the road when my warranty is out. I grabbed a oil sample from the crankcase when I drained out the mixture and plan to send it in to see if anything shows up in it. I have it at the dealership now getting repaired. I did tell the service manager I caught an oil sample made him put on the work order diesel in the oil, loss of oil PSI and low fuel economy. Does anyone know if a high concentration of diesel in the oil will harm the Turbo, bearings or rings. Thanks
    Mar 2007
    Pacific Northwest
    Talking
    The funny thing about the fuel in the oil is this......... I have changed injectors in DMAX's that had over 7 GALLONS of oil in the crankcase!!! And these vehicles are commercial vehicles that are driven HARD! I change the oil and filter and send the truck on its merry little way. I haven't seen any issues yet. I work at a Light/ Medium Duty GMC dealership and most of the trucks sold (2500, 3500, 4500, 5500 C/K trucks) have the DMAX engine in them. I guess what I am getting at is that ISUZU must have put one heck of a set of bearings in that engine because I have only replaced three DMAX engines since they came out in 2001 and none of them were for bearing failure!!!
    NutNbutGMC Guest
    Quote Originally Posted by cmwilga
    Thread officially jacked....
    Fuel injectors...not injections... LOL....
    Where did Skinny Blinky go?
    I had three sets of warrantied injectors in a 2K2. Nothng but a nightmare. I can tell you all that you can read here. Short of the long is to find a stealer-ship that will do you right with the full replacement version of GM's directives (TSBs). Once that is committed, getting the injectors is the next problem (info that I found out first hand and keep hearing it). Then make sure the mechanic has some experience directly related to this repair. A good mechanic can do it in a day (good as in experience with this issue). A new guy can take up to 20 - 30 hours. I talked to a guy just last week that had the new guy do his.
    Apr 2007
    Default caroded up ball seets
    I heard from the service manager at the dealership and he said all of my injectors were rusted and caroded up as if I had been running bad diesel in the truck. GM did not want to cover it under the warranty. He said after spending two hours over the phone with them they agreed to cover the replacement cost of $4200.I have been getting my fuel at the local Fina station and also have been getting clear diesel delivered to a 500 gal metal tank at my house and filtering it to my truck. Have you guys ever heard of rusted and caroded injectors and what would cause it. I have never seen the water in fuel message come on but now I am scared to use the tank I have set up at my house. The service manager also told me to quit using baldwin fuel filters and use GM only.
    Nov 2000
    foxboro,ma.
    sounds like the MGR wants to get double paid for the same job.... your $4K and Gm paying for 8 new injectors with labor. I would not let them do any work without seeing a fuel sample and a gas station rep present with a whole bunch of fuel samples tested fron the same station not knowing your building a case against them.... I hate to say it but your in for a fight , when a dealer claims bad fuel GM will not do much to help the little guys like you and me ! I had a bad tankfull of wet fuel on my 2001 , my local Hess station where I had just filled up the night before said....No couldnt be we have the best fuel in town or any where for that mater ! That was the last time I spent $.01 with those a holes...... well them and Mobil , 10 billion dollars in profit... None of my hard erned money.
    93 c-2500 6.5td,96 6.5td x cab,01 GMC lb7 Xcab ,2004 lly crew cab ,2006 lbz crew cab,honda CBR1100xx,2003 polaris prox 700 , 2001 31' holiday rambler 10K lbs house on wheels!
